SOURCE: Shutter Blades out on Minolta Maxxum 7000
It is possible to fit them back since they are flexible. It does require a gentle touch, with a lot of patience. I use angled tweezers for this task.
Replacement parts are no longer available. Used cameras can be found on ebay and the like.
SOURCE: The sprocket in my Minolta
The battery holders were known for corrosion buildup at the pivot point, your batteries might not be making good contact.
SOURCE: how do i replace internal battery on the minolta
On the bottom look for a round cap with a slot through it. You may be able to use a dime or quarter to turn it right to left it will unscrew replace the small button cell batteries found a camera store or radioshack
SOURCE: Is the Minolta Maxxum 7000 capable of using infrared film?
goneoutthewi,
once the shutter is closed or the shutter open and the mirror is up no light strikes the film except the image. don't forget to use the red markings on the lens as infra-red focuses on a different plane than visible light.
SOURCE: Blinking 0 on my minolta maxxum 5 after I loaded
It did not load your film. open the back, be sure you have the film pulled across the opening to the far side of the take-up spool, and close the back again. It should make noise as it winds the film, then number 1 should appear in the top window. If it does not make noise and advance film, you likely need the film advance motor replaced. Every time you close the back, it will try to advance film.
The motor itself can die and those plastic gears can break teeth. If repositioning the film does not work, your maxxum needs a trip to the repair shop.
