SOURCE: no picture no sound and power light blinks.
Did you check the supply fuses to the convergence ICs? Did you check the output resistors
other wise i would replace the convergence ic first.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: power light blinks but no picture or sound
The power light is using the same small 'always on' power supply that keeps the infra-red receiver for remote functions alive too.
It is likely that the main power supply is sick and will need repair or replacement.
This is probably a separate board (these are often outsourced to specialty companies) and should be user replaceable once you identify it.
What you can do is; unplug the set, let it stand
overnight or at least several hours, remove the back panel and look for a
separate board with mostly larger components on it; it will have a ferrite core
(no laminations as with a line-frequency part) transformer on it and several
larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on
that board, allow several hours to be safe since the larger capacitors can hold
a painful voltage charge for some hours.
If you see signs of overheating such as
discoloration of the board material, the PSU may not be repairable but if you
can find a part number on the board, you might be able to buy the power supply
from the mfr.(or company linked below) and install it yourself but it will likely have the same problem
eventually unless they have altered the design or improved component quality.
If there are no signs of heat damage to the board,
there may be companies offering to repair it as a subassembly instead of
repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the main
power supply still may not be at fault since most are capable
of switching on and off if a downstream problem is causing an overload and the
power supply for the backlight may be at fault.
Possible board source:
Jimmy's Parts
Testimonial: "great information! thought it might be power supply but needed expert view and advice. Thank You very much."
