Motorola Mobility i835 Cellular Phone Logo
Anonymous Posted on May 24, 2010
Slight water damage
I have a motrola i850. it got water spashed on it. i dryed it off with a cloth and used the plow dryer on low. it was working and i could dial out and direct talk, with the exception of the screen getting foggy. then my husband took out the battery and opened the sim card now there is no screen and its turned on, and i cant even dial out or direct talk. what can we do?
Anonymous
Level 3:
  • Master 813 Answers
  • Posted on May 24, 2010
Anonymous
Master
Level 3:
Answers
813
Questions
0
Helped
216738
Points
2234
Most probably the motherboard is damaged or some components are shortened out. You may try to take out the battery, SIM and memory cards and let it dry in sun for 1 day. Then put in the battery and then check again. If it still fails to start - you need to get it check by some qualified tech.
My new vaporella 650 steam iron is making my clothes wet whilst ironing as it drips water constantly
Clothes are very difficult to iron when they are fully dry or over-dried in the dryer. Over-dried clothes are resistant to reshaping, which it exactly what ironing is. Removing clothes when they are still slightly damp will make ironing much easier. If you line-dry your clothes, bring them inside to iron when they are not quite dry.
Nov 12, 2017 • Irons
What is the best settings to wash jeans on.
While hand washing and line drying is safest, it's also costly in terms of time and effort. Unless your jeans are particularly dirty, it's best to wash them in cold water, select one of the gentler cycles, and dry them at a low temperature. Special detergents formulated to preserve dark colors really do work.
What temperature do you wash jeans? When to Use Warm Water - For man-made fibers, knits and jeans, use warm water (90°F). Most of your clothes can be washed in warm water. It offers good cleaning without significant fading or shrinking. When to Use Cold Water - For dark, bright colors that bleed or delicate fabrics, use cold water (80°F).
Wash your jeans in the sink or a tub.
  1. Fill a tub with a few inches of cold or lukewarm water. Mix in a gentle, color preserving detergent.
  2. Turn the jeans inside out, then lay flat in the tub. Don't bunch them or wrinkle them. Let them soak for about 45 minutes.
  3. Run them under the water to rinse. Hang up to dry.
  4. Can you put jeans in a tumble dryer?
    According to Good Housekeeping "All fabrics and especially jeans benefit when youtake them out of the dryer slightly damp. ... If, even after tumbling on low heat and a delicate cycle, you see lots of lint on the dryer's filter, you may want to switch to linedrying your jeans to help preserve the fabric.
    hope this helps you out.
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
I was taking a shower and the team got into my next book 7 now i cant get pass the loading screen how can i fix steam damage
first thing i got to ask..did you try using a hair dryer on low heat to dry your hair and tablet after u figured out eletronics and water dont mix?
next time try a ziplock bag to keep it dry..ahaah. just kidding.
here is a link i use to walk customers thru opening up a tablet..follow it close.. if open it up and use a soft cloth and gently dap any standing water..then let it AIr dry for 24hrs..then if still not working..plug in power for while to warm up..use a hair dryer on low to dry any hard to reach spots..if it still doent power up...use it for a soap holder and buy new one
good luck
chad man
I am having 2 issues. Most importantly, my front load washer/dryer is skipping drying time. I typically wash the clothes then put dryer sheets in and use the dry only on low heat option. It starts...
Your two issues may be related. A combo washer / dryer uses a fine spray of cool water to condense moisture out of the air stream while drying. This water is then pumped down the drain. Cold water is also used to fill the softner dispenser. If the inlet screen on the cold water connection to the machine is restricted, those are two of several things which could show up. Turn cold water valve supplying water to machine off. Unscrew cold water fill hose from machine. Remove screen from inside machine, clean, re-install, re-attach cold water fill hose, turn cold water valve back on and see if performace improved.
3helpful
Takes 5 hours to dry a medium load of clothes. Clothes feel slightly warm and damp when removed.
clean out your dryer vent the hose going from your dryer to your house the vent from your laundy room to the out side of the house make sure the vent is as straight and possible and no kinks
also clean your lint screen with soap and water if you use fabric sofener sheets they have a chemical that clogs the screens the watter should flow right thu the lint screen and not puddle up at all
do this asap you are risking damaging your dryer and worse yet your house could catch fire
Dryer working but not blowing hot air
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
My blackberry curve 8350 i got wet and it does not work. What to do to fix?
Once a piece of electronic equipment gets wet, you need to disassemble it, remove the battery and dry it carefully using a lint free cloth. Then use a hair dryer to dry it out. Do not put the hair dryer too close as you could overheat and damage the item. If you wait too long to do this, the water may have already fatally damaged your phone. Good luck!
Mar 01, 2010 • Nextel i850
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
2answers
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
