True 72 cu. ft. / 2039 liter Commercial Freezer T-72F Logo
Anonymous Posted on May 24, 2010
Door jam icing up
Freezer model # is T-72F
Ice is building up around outside of door jam. Already replaced door seal.
Dennis Boxerman
Level 3:
  • True Master 1,306 Answers
  • Posted on May 30, 2010
Dennis Boxerman
True Master
Level 3:
Answers
1306
Questions
Helped
646979
Points
2787
Door has to seal tight. also, there are door frame heaters called, "Anti Sweat Heaters." It is to prevent condensation and ice build up around the doors. Have that checked out.
Testimonial: "Yes, The door was the problem. i got power to it but its not warming the door. Can the element in the door be replaced or do i have to replace the whole door?"
1helpful
Kenmore Upright FrostFree Freezer 26072. Get ice on inside top of door near gasket that goes around). Ice forms on the inside top edge of the unit, where the door problem touches. How to repair?
An ice build up around the top of the door aperture isn't unusual due to some cold dense air from inside will spill out when the door is opened to be replaced with humid lighter outside air that will tend to remain at the top for a while.
Being frost free doesn't exclude it from this type of ice build up as only ice formed over the evaporator during a cooling cycle will be melted by the defrost heater.
Persistent localised ice build up could be a sign of failing insulation but this will be marked by a cold spot on the outside of the cabinet.
Why is ice forming around the inside freezer door?
You have bad door seals. Try hitting with a heat gun type, dryer just a little heat.. Then close door for 24 hours
Oct 29, 2015 • Freezers
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Freezer builds up frost and ice too quickly.
Either the door gasket is not sealing well or the unit is low in refrigerant.
Sep 24, 2009 • Freezers
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Kenmore upright freezer not cold enough to freeze
Sounds like a door seal that isn't sealing all the way around. That would be my first replacement. Is the unit level back to front and side to side? Is it really full of food?
Call your local appliance parts house and get a magnetic door seal first. They aren't that expensive. But make sure you do not have the freezer overloaded, which could account for the lack of that vacuum sound.
Finally, is self defost? Even if it is, a lot of times the vent on the bottom in the back gets packed with ice. If it is, remove the food and use a hairdryer, being carefull to unplug the freezer first. Melt all that ice and empty your overflow tray at the bottom underneath.
Frost buildup in frost free freezer
There is a defroster built into the ice maker to melt the ice a little around the edges before dispensing on most ice makers it may need replacing.
Jul 28, 2008 • Freezers
Top of freezer thawing
Ice build-up in the area of the door could be causing the door gaskets to loose their seal. Shut the unit off and use a hair drier to melt the ice away from the door area. Return the control to run position and see if it makes a difference.
Top True Freezers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a True Freezer Expert? Answer questions, earn points and help others
