Dear customer
You need software flash for your handset.If u are not a Technician then its better to go ur nearest Blackberry customer care.If u are satisfyd by my information then please vote me .Thank you for visit.
You want reload os to your device
BlackBerry Handheld Software v4.6.0.378 from
DoCoMo
(Contains English)
This OS will load to ANY carrier's 9000 model by following the
instructions below.
Package Version: 4.6.0.378
Consisting of:
* Applications
: 4.6.0.224
* Software Platform: 4.0.0.187
* File name: 9000jEastAsia_PBr4.6.0_rel378_PL4.0.0.187_A4.6.0.2 24.exe
* File size: 97.3MB
(This download is a zipfile and will decompress to the .exe file stated
above)
Download here: http://smartphone.nttdocomo.co.jp/fa...old_460224.zip
1. Download the above OS file to the PC then install it to the PC by running (double
clicking) the file you downloaded.
2. Go to c:\program files\common files\research in motion\apploader and
delete the file named "vendor.xml."
3. Plug in BB and double click on "Loader.exe." It's located in the same
place as the above vendor.xml file.
The process takes about 45 minutes to an hour depending on how much data
you have to backup and restore during the process. Once it's done
loading the new OS it will reboot (it may do this twice during the
entire process.) You will see a white screen with an hourglass for up to
20 minutes at a time while the DM says "waiting for initialization."
If, for some reason, you end up with a white screen with small icons and the number 507,
simply connect to the PC again and run Loader.exe again and it should
load the OS to the device.
just look at here for more techniques
http://supportforums.blackberry.com/t5/BlackBerry-Bold-BlackBerry-9000/blackberry-bold-9000-reload-software-513/m-p/180591
