Bosch Nexxt 500 Plus WFMC5301UC Logo
Posted on May 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door won't unlock and cycle won't start
My washer will not start a cycle. When I push the start button, I get 3 quick buzzer-like sounds and then nothing. The door is also locked, and I cannot get it open. It will not unlock, and the "door locked" indicator light is NOT on.
ben fixit
Level 2:
  • Expert 42 Answers
  • Posted on May 25, 2010
ben fixit
Expert
Level 2:
Answers
42
Questions
Helped
35310
Points
102
The interlock has failed most likely. Its a small electronic part that the door catch connects into when you close the machine door. Its tricky to release but can be done. Unplug the machine, remove the lid, put your hand down the front of the machine to where the door catch goes in and fiddle until it releases. It takes a bit of luck when you dont know what your looking for.
1helpful
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Cenral locking won open the tailgate fuse 1 ok
It normally DOES NOT Unlock with the Door Unlock. Depending on the Year/Make/Model. Some have a Separate Button, Some you have to Push 2 QUICK Unlocks for it to work, then there is one I ran into that you had to push it 3 times (I though that was odd).
One Quick Push = Drivers Doot
Two Quick Pushes = All Doors
Three Quick Pushes = Trunk
2answers
How do I get the door to open on a Maytag washer that remains locked?
It sounds like the timer is defective. You may need to call a Maytag sales and/or service center and ask them what to do. WIll the washer start a new cycle?? If so start a new cycle and swee if the machine will get past this sticking point next time.
Wfw97hexl0-door is locked and won't unlock or run a cycle just makes a buzzer noise every couple of seconds.
did you try to press the stop button then change the cycle to another then press the power button then press and hold the start button again that works most of the time.
WFW94HEXW door won't unlock and Door Lock isn't lit
if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock.
2) if do not obey press and hold END OF CYCLE, wait about 10seconds
3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
God bless you
2helpful
Control lock is on and nothing works
push and hold the end cycle buzzer button for 3 seconds this should unlock the controls
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
2helpful
2answers
Kenmore 70 series model # 96573220
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
