Swiss Army Wenger Sportedge Bracelet Watch Logo
A
Anonymous Posted on May 20, 2010
How do I change the date on 30-day months without changing the day?
Anonymous
Level 3:
Genius:
  • Master 1,970 Answers
  • Posted on Jun 15, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1970
Questions
0
Helped
847668
Points
4702
In most cases the winder has 2 positions, mcdevito 75 here, pull the stem out very carefully to it's first position, this should allow you to change the DATE (number) by turning the stem eithe toward you or away, once you get the Date, pull the stem out to it"s 2 nd position and turn the hands until you get the correct day. mcdevito 75
How do I change the month on an MK 5629?
At the end of a month with less than 31 days you must manually advance the date.
Aug 30, 2014 • Watches
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 • Watches
tip
on Jul 09, 2010 • Watches
6helpful
2answers
I Have a fossil 10 atm watch & the date doesn't change automatically so i change it manually but then half way thought the day it changes the date
Your watch is 12 hours out of step.
The date changes every second time the hour hand passes 12 O'clock.
Your watches' second pass is at midday instead of midnight, so to make it operate correctly, you need to wind it on 12 hours. The date will then change at midnight.
I have a TAG Aquaracer Automatic. Should it not compensate automatically for months with only 30 days, such as September, November, April and June? At the end of September, the date changed from 30, to...
Your watch is a mechanical type for which there is no way of making it skip days. I have the same operation on my watch which although it has some electronic circuitry, variable month lengths is not one of the things it can compensate for.
Electronic watches can do this because they have flexible software which can be programmed to "remember" the length of the month.
Oct 04, 2010 • Watches
The date adjusts at 1am. any solution? thanks
mcdevito75 here, That sounds about right, each watch is slightly different, some watches, have the date change at 10:30 PM and some at 11:00 PM, and if your Tag also has the month or day to change along with the date, this could account for the date changeing kind of late. I don"t think it"s anything to worry about.
2helpful
GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
2helpful
Set day of month
The day is changed when the watch passes midnight or thereabouts. Turn the winder until the date changes and then turn it backwards until it is past the date changing point and wind it forwards.
You will have to experiment to find how far back you need to turn it before going forwards again.
3helpful
How do i adjust the date on my classic watch?? pull the pin and rotate cw or ccw no changes.i have an indigo classic watch. does date need to be adjusted every 30 day months? thanks
You have to adjust the date every February (28 or 29 days), April, June, September and November (each 30 days). Self adjusting calendars are called Perpetual Calendars and this feature is quite expensive, especially in mechanical watches. Your watch has calendar ring with 31 days printed on and the simple calendar mechanism which is changing dates from 1 to 31 inclusive,day after day, so, when the 30-day month is ending and there is no 31st date to follow, your calendar is showing 31st anyway,instead of 1st of the next month. This is when you have to adjust date. Now about the date adjusting. If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
1helpful
Changing date...
When your winding the month over prop it so that its not quite all the way turned around or just turned around this works for me. Hope it works.
Top Swiss Army Wenger Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Swiss Army Wenger Watch Expert? Answer questions, earn points and help others
