Owners manual I have a 42 inch GE HDTV monitor Model D52GW12 and lost my manual. I need to reprogram my channel to coincide with cable. Where can I download one? Please help Thank You Suzy
you can use the user manual, if none you can manually reprogrammed every channel. just go to set up menu then go to channel set up the select manual fine tuned.you can use the channel up/down button then the volume up/down button to search every channel program.
You may have a bad tuner in this set, if the rear audio/video inputs work with a DVD etc you can get a cable box and connect to a rear input and bypass the entire problem.
If you need a tube replacement, your best bet is to get a used one from ebay. You need to verify the numbers on the side of the tube. Note: this is a very hazardous part to be handling. If you do not have an electronics background I strongly suggest you not attempt to replace, then re-align the tv.
You can get any replacement board that you require for your model from www.tvrepairworld.com they will also help you determine which board is correct for your model and symptoms.
Use your input button on your television's remote control.... you should have plugged the wires into the COMP 1 area on the back of your TV. You will also need to make sure your red and white audio cables are plugged in as well (Five total plugged wires) Press the input button until you see COMP1 at the bottom of the screen... there you will find your picture and sound.
I need to see the owners manual to a 42 inch LCD Sony TV
