This battery tells you how to load test a battery, about connection being clean. Also that new batteries aren't always fully charged. He explains the solenoid function
Have you checked the battery terminal connections? Is the battery charged fully? Are you sitting on the seat when you try to crank the mower? Could be any of the above but most likely battery connection or the battery is discharged or old.
Hi. Begin by fully charging the battery. If it won't take a full charge, replace it. Once the battery is fully charged it will turn over. Then it should start. If it doesn't start then, get a can of starter fluid and put a couple of squirts into the air filter. J.
No, it sounds to me like it is one of the safety switches is a bit corroded, along with a battery that may not be fully charged, you are not getting enough voltage to turn the engine over. What I would first do it disconnect the battery, take apart all connections of the cables, where it mounts to solenoid, where ground cable connects to the tractor, etc. Then put everything back on. Charge the battery, or jump the tractor to get it started and let it run a bit, which will charge the battery. You may need to check wire connections that go to various safety switches, too. Under the seat, where it connects to the transmission, etc. This does not sound like a big problem at all.
YOU NEED TO REPLACE THE SOLENOID IT IS SHORTING OUT AS TO THE GAUGE THEY WILL NEVER MOVE AS THE GENERATOR CHARGES ONLY WHEN THE BATTERY HITS 9 VOLTS THEN IT ACTIVATES TO CHARGE BACK TO 12 VOLTS BUT IN SMALL INCREMENTS
