Computers & Internet Logo
A
Anonymous Posted on May 20, 2010
Where to download the driver for hp pavillion dv6226tx lan (ethernet) driver?
Frank Zabroski
Level 2:
Sergeant:
  • Expert 268 Answers
  • Posted on May 24, 2010
Frank Zabroski
Expert
Level 2:
Sergeant:
Answers
268
Questions
Helped
70470
Points
685
Support section of hp.com. Just enter make and model type of operating system and you will have all needed drivers and software.
Please keep me posted and updated on your issue. I am here for you and will see your issues out till resolved.
Have a great and wonderful day :)
Thank You
Please do not hesitate to contact support :)
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
http://www.itsupport.co.cc
1helpful
HP Pavillion ze 2000 has no wireless connectivity
Try installing the latest audio and LAN drivers.
You can download the audio, LAN and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
HP Pavillion desktop a6210in network driver
You can download the LAN and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
1helpful
I need a hp pavillion a1620 ethernet controller driver. which site can i best download it from?
Google hp's site and then look for the tap/link that says SUPPORT or download drivers once you're on their site. Then you'll need to put in which hp pavillion you have and operating system. That should take you to another page where all the drivers are including your ethernet driver.
It is always best to go directly to the manufacturer's site for drivers and match the specific model and OS.
Im having trouble installing the ethernet controller for a hp pavillion media center a1620n. i have tried the manufacturers site for the driver and it did not work. can someone help please?
You can try to used this :
http://cgi.ebay.com/Ethernet-10-100M-NIC-PCI-LAN-Adapter-Network-Card-RJ45-/280630007091?pt=COMP_EN_Hubs&hash=item4156da1533
Thanks
2answers
My device manager always show missing drivers ethernet controller and base system device,i can not reach it
Hi!
To fix this, you have to download and install the Chipset and Ethernet Drivers, which can be downloaded from the following link from HP Official Support: -
Compaq nc8000 Drivers
Visit the above link. Click the Network Drivers link and download the drivers for ethernet (LAN) according to the LAN you have on your laptop. (you may try other Broadcom or Intel LAN Drivers)
Also, from Operating System enhancement section you can get the chipset drivers
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Format hard drive for HP pentium 4 desktop computer and install Windows Xp sp2 but can not install the ethernet controller for LAN connection to server.Needs driver software for ethernet controller and...
You need to download the LAN driver with a computer that has Internet access and the copy and install the driver on your computer.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
2answers
Install lan Driver
You may download the LAN and all the other Drivers from the below link:
http://support.acer.com/drivers_download.aspx
Select the exact Model # of the Computer and download the Drivers.
Hope this helps.
3helpful
3answers
I have failed to install ethernet driver after
your operating system should detect and install the drivers for your network controller if it is an internal on board LAN. however you must be sure that you have the LAN enabled in your BIOS setup under the advanced selection on the bios screen. otherwise , your operating system won't even see that you have a LAN connection.
HP Pavillion dv2000 is not detecting the network cable for lan
ok...so...unhook the cable completely
go to control panel
device manager
and see if the ethernet device is clear or has some mark on it..you may need to remove that or disable it, then re install
Grand Canyon Tech
Grand Canyon Tech
