I have the exact same problem. The door closes fully and then re-opens immediately.I have the exact same problem. The door closes fully and then re-opens immediately.
AnonymousApr 08, 2008
After garage door closes, it immediately goes back up.After garage door closes, it immediately goes back up.
AnonymousApr 10, 2008
need wiring instructions for chamberlin garage door safty sensorsneed wiring instructions for chamberlin garage door safty sensors
AnonymousMar 20, 2014
the door starts to close and immediately opens back.the door starts to close and immediately opens back.
You can't post conmments that contain an email address.
? 3:41 https://www.youtube.com/watch?v=b8w2w5ZAc1I
Feb 5, 2014 - Uploaded by Andrew Hill
How to Fix A Garage Door Opener - the opener shown is the Craftsman 1/2 HP ... First start with the obvious and easy to check problems. ... opener button on the wall will open the garage door but not your remote or keypad, ...
Jun 5, 2014 - To help you troubleshoot your garage door issues, here are the top 10 ...Garage Door Closes Part Way, Then Opens Again ... Automatic Garage Door Opener Runs for a Few Seconds then Turns Off but Door Doesn't Move
That sounds like an adjustment issue. Say you leave something in the path of the garage door coming down. As soon as it hits it, it is going to immediately stop and move back up. With the garage door improperly adjusted, it is "thinking" it is hitting something when it touched the ground. There should be adjustment screws on the motor. Check your user manual to reference.
If your garage door will not close from the open position and reverses immediately or part way down there is a safety beam problem, usually there is a safety light on the opener which will flash when the safety beam is activated or faulty. Clean the photo beams with a clean damp cloth, check if the door now operates, if it does not, check that the safety beams have not become misaligned, there is normally a light on one of the sensors that indicates when they are correctly aligned, if the light is on it means they are not aligned, the light off indicates they are aligned. If they are not aligned try adjusting them, if this does not work they are probably faulty. Further reading garage door opener repair guide
I can't help you on programming.
If the door goes up as soon as it touches down, it is going too far down.
Locate the adjustment on the box on top. There should be four adjusters:
Door down amount more or less
Door up amount more or less
Force down more or less
Forch up more or less.
Turn the Door down amount toward the "LESS" or "-"
Let me know how you do.
Gary
make sure that the auto matic reverse circuit light is being read correctly. they is a light extending a beam of infared light, you can't see it, to a reflector across the garage at the floor level at the garage opening. There should be an indicator light, usually green and red. Line up the light and reflector until the green light comes on.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
There will be adjustment knobs on the side of the unit. Usually two white knobs that you have to turn with a small flathead screwdriver. These are the limit / load adjustments.
These adjustments are VERY sensitive, so be patient!
