Computers & Internet Logo
Posted on Apr 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Imation pocket flash drive and I'm trying to copy music files from my old computer (Windows 98) to my flash drive and I keep getting error message "unable to write". Any suggestions?
Hollyecho Montgomery
Level 2:
Sergeant:
  • Expert 318 Answers
  • Posted on Apr 06, 2008
Expert
Level 2:
Sergeant:
Answers
318
Questions
0
Helped
158187
Points
845
You need a driver for the flash drive to work in Win98. You can download it here:
http://driverscollection.com/?file_cid=393499707811d1cd9a955402f23 - if your win98 computer is connected to the internet use it to download the file, then your flash drive will work
How to put music on a flash drive
Open Windows Explorer so you can see the Flash Drive. Select the music files you want to copy, Holding the Right Mouse button down, Drag and Drop the files onto the Flash Drive.
Let go the Right Mouse button.
Click "Copy" from the window which comes up.
1helpful
IMac won't read Imation 160GB Apollo 2.5
Mac's won't read windows format disc, even if it's capable of reading the files wich I believe Newer Mac Operating Systems CAN DO, it can not read the file SYSTEM used to place them on the disc. You need a third computer. Put the files on a nother computer or two if you need the room or on another media or pocket drive. Use a program that VERIFIES the were moved without errors while copying them, the use the Mac to format the now empty disc drive and download Mac Pooler, or File Stuffer, and copy the files back onto the disc. Now the Mac will be able to read the drive they're on.
1helpful
Transfer files from one computer to another
The easiest way is to have something like an external hard drive or usb flash drive then copy the files from the old computer and then take the usb flash drive or external drive and and plug it into the new computer and copy the files to it.
You will be using the concept of copy and paste or drag and drop to get the files.
You can only copy things such as your documents, music, pictures and videos. You cannot copy programs from one computer to the other, programs have to be reinstalled so that they can update the registry and other settings in windows to work.
The majority of your documents, music, pictures and videos will be in your MY DOCUMENTS folder.
2answers
I want to copy music folders to the 8gb sahara usb flash drive but is saying I cant is the drive is protected
click start all programs accessories open windows explorer navigate to your music files right click on the music right copy navigate back to the destination drive right click select paste or hold the
mouse cursor on the music files drag them to folder
then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another
device floppy or a usb device
if you need more help with this post a reply
hope this helps
Need to reboot computer,windows98,invalid disk error
You have to go into your BIOS and select booting from Disk not hard drive when i say disk i mean either the cdrom or dvd disk players attached to your motherboard. also you can get a boot disk to try that at the link below.
http://www.allbootdisks.com/download/98.html
My louck flash is formated and now i can not use the space what do i do?
Your Imation Swivel Flash Drive comes formatted and ready to use right out of the box.
If you will be using the drive exclusively with Macintosh computers, do not format the Imation Swivel Flash Drive. The formatting message appears if your Macintosh has not yet been set up to read Windows-formatted files. Refer to your Mac's user manual to learn how to enable Windows file read functionality.
Also, be aware that when you format your Imation Swivel Flash Drive with NTFS, you will not be able to store as much data as your would without formatting. The format file used by NTFS will use some of the available space on the Flash drive - for instance, on a 128MB Imation Swivel Flash Drive, you may lose up to 8MB to the NTFS format files.
How do I format my Imation USB 2.0 Swivel Flash Drive in Windows? Your drive must be set up as a single public partition, since neither Windows Explorer nor the Macintosh OS will recognize a password protected partition.
To format the drive in Windows:
  • Go to My Computer
  • Locate the corresponding drive letter for the Swivel Flash drive (i.e. removable drive F)
  • Right click
  • Choose Format from the menu
A dialog box will come up and allow you to format your Swivel Flash Drive. Depending on your operating system, you can choose to format the drive in FAT, FAT32, or NTFS.
How to I remove or resize a partition on my Imation Swivel Pro Flash Drive? To resize or remove a secure partition, you will need to do the following:
  • Open the Flash Manager software on your hard drive
  • Choose Create a partition
  • Move the slider to zero (0)
Why don't I see a drive letter for my Imation Swivel Flash Drive?
This problem occurs if you map a network drive to the first available drive letter following the drive letters for the local volumes and CD/DVD drives. When you install a new device or volume, a software called Mount Manager tries to assign drive letters to the new volumes. But since the software does not recognize mapped drive letters, it assigns the next available local drive letter to the new device. This causes a collision with the existing mapped network drive.
Since the problem is related to your Microsoft operating system, they are your best source for resolving this issue. For more information, click here.
How do I get all my old info, pics, documents and all stuff saved from my old desk top computer compaq presario 5700n windows 98 second edition so i can put it on my lap top, my flash drive won't work on...
Take the hard drive out and get someone knowledgeable to put it in their system as a slave drive. Then plug your flash drive into their system and copy all the files to it. I'd say this is the fastest and easiest solution to the problem. You could always network it to another computer and transfer the files also.
Computer won't convert music on flash drive
Try to put the files directly in the Music folder inside My Computer>Player device, from the flash drive, just to be safe make sure they are in mp3 or wma file format also.
2answers
Imation atom usb driver vista
vista has this problem , see below webite
Error message when you try to install a new hardware device on a Windows Vista-based computer: "Windows encountered a problem installing the driver software for your device GET basis information
http://support.microsoft.com/kb/940199/en-us
Grand Canyon Tech
Grand Canyon Tech
