Garden Logo
A
Anonymous Posted on Jun 23, 2017
We purchased a used Husqvarna VTH150 Tractor with a mowing deck. We got an aftermarket snowblower attachment with it that we had attached by a dealer. We have removed the snowblower attachment and wish to reinstall the mower deck ourselves. our problem is that we don't have an Owners Manual and can't find one for this VTH150 model on-line. we found one for a larger Husqvarna but the larger deck is of a different design. can you help us?
Richard Haynes
Level 3:
Master:
  • Husqvarna Master 673 Answers
  • Posted on Oct 26, 2017
Richard Haynes
Husqvarna Master
Level 3:
Master:
Answers
673
Questions
0
Helped
208110
Points
1403
There is a problem with your model number. Look under the seat, there should be a model number listed on the serial number plate. Take that model number to: http://www.husqvarna.com/us/support/manuals-downloads/
and download your manual.
5 Related Answers
Anonymous
  • 405 Answers
  • Posted on Dec 23, 2008
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Anonymous
  • Posted on Mar 31, 2009
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Anonymous
  • 10865 Answers
SOURCE: Installing mower belt
The pulley at a wierd angle is the tension pulley. You may get the manual on line for free if you are lucky but not all mower manufacturers are that generous. What kind of mower do u have?
Anonymous
  • 81 Answers
  • Posted on Jun 22, 2009
SOURCE: HYDRASTATIC TRANSMISSION DOESN'T MOVE
Far as I know the warranties are not transferable. Some hydrastatic transmission fluid can be checked by removing the battery and underneath there is a place to put the fluid and to check it. But not all models or makes gives you this option.
Anonymous
  • 44 Answers
  • Posted on Jul 21, 2009
SOURCE: 48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
How do you Assemble the anti-sway rod on a Husqvarna mowing deck?
The anti-sway bar fits into the frame. Then the sway bar then fits into the deck and connects with a washer and clip.
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
There is a big, wrap-around lifting bar in the front of my Husky used to raise the engine assembly off the mowing deck but I can't figure out how to free the engine assembly so I can pivot it up to expose...
most rideons have the deck assembly able to be removed without too much work.usually release any spring tension,then spring clips holding the arms on,then usually you can disconnect the belts and slide the whole deck out sideways,from under the rider.
How do I install a mulching Kit on my Husqvarna riding lawn mower?
having trouble with mulching unit on 22hp tractor.Mulching kit installed by dealer at time of purchase.What is happening is grass is kicking up on the top of the mowing unit,covering the belts and everything else.I need to do a major cleaning every time I use the tractor.Any one got some solution.
Hard start or won't start
the float in the fuel bowl might be getting stuck what you can do is push & pull on float to see if it flows if not the replace the float if i can help further e-mail me wade @ [email protected]
Need deck belt diagram for huskvarna yth2242t lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action and enter your model number, Then scroll down the subcomponent list to Mowing Deck. There ya are.....
1helpful
Mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
