You can bypass the internal rheostat by attaching the two wires at the rheostat together via soldering and sealing with heat shrink tubing or use a wire nut then buy a wireless thermostat you will then plug your heater into. Amazon sells one with a remote control for a lot less than a new heater ($24.95). You simply plug the thermostat into your wall plug and plug your heater into the thermostat and wallah, no more heater problems!You can bypass the internal rheostat by attaching the two wires at the rheostat together via soldering and sealing with heat shrink tubing or use a wire nut then buy a wireless thermostat you will then plug your heater into. Amazon sells one with a remote control for a lot less than a new heater ($24.95). You simply plug the thermostat into your wall plug and plug your heater into the thermostat and wallah, no more heater problems!
You can't post conmments that contain an email address.
Dear Sondra,
You might well have started a fire in your walls.
You are very observant.
Please do not plug this machine in again.
Take it back to COSTCO somewhere with the store receipt and they should replace it or refund the money.
You will need to find the store manager.
Please do not list your phone numbers on a public web site, because people can read this who you do not wish to do so.
God bless your efforts.
Can you use a continuity checker, and get into the inside of the control panel cover?
You need to check continuity, from one side of the plug, in thru the switch, thermostat, and limit device, thru the element, and back to the others side of the plug--
Can you do that?
Let me know how your continuity testing goes, and get back with me, on what you find.
I like taking things apart. Usually something like that it is an internal fuse or a switch/wiring issue. Not worth taking to someone to fix--not worth the cost. Try taking it apart.
Hard to tell without more information. Bets to call Presto customer service at 800.877.0441. Have the model and series number found on the back of the base.
no repairs, however you do have a full year warranty.Just return it to Costco and they will exchange it for you.
Linda
NPI Customer Service
Shipments made to U.S. or Canada only
(original message)
I bought a Presto Heat Dish at Costco (Calgary) and not even a year later the control switch's filament burned out. can you send a replacement switch or provide me with a local supplier so I can return the defective unit and repair it myself?
Or try a thrift store for a used one. Do a search for "heat dish" without the quotes, and you will get a few hits. Amazon.com has a few of this type of heater.
