Sony KP-51HW40 51" Rear Projection Television Logo
Posted on May 24, 2010
Picture is unclear color are off
The red yellow and blue are not in alignment,picture is fuzzy and blurry and warped
Anonymous
Level 1:
New Friend:
  • Contributor 111 Answers
  • Posted on May 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
111
Questions
0
Helped
34374
Points
22
There are a few things you might be able to do. First I would try the auto focus or alignment feature of the set. there should be a option in menu to realign the lamps.
Fuzzy picture help 55" rear projection toshiba
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused trouble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is installation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
1helpful
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites MCMElectronics.com,Tv reapair World.com to buy CRT tube coolant to recharge ur CRT.
When i try to align the colors. red and yellow align but blue will not align
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
My tv is blurry, showing green and red waves...zenith d61w25
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
Green Background with red wavy lines
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
HO board
CONVERGE PROBLEM
hello,
60pp9202 About 2 days ago tv went blurry -all colors separated!
I first tried factory setting convergence - NO GOOD!
Then by hand one cross aligned at a time (red mostly, and green, the blue doesn't show misalignment) , tv won't save my efforts after I shut it off.
The crosses around perimeter are bend like bows , so when you try to bring yellow and red crosses together to align with "converge red"- they can't line up because red and yellow crosses are bowed-bent opposite, in center they are closer to straight be still all are a bit warped! images on screen are now also warped as well! If there are any of you in the Queens nyc area that can come and do a good repair- I would be glad to pay a decent fair price! (917)687-6290 CALL ME IF YOU CAN COME TO FIX IT (2PM-8PM) [email protected]
I WOULD ALSO APPRECIATE ANY ADVICE! CAN I FIX THIS MYSELF BY CHANGING A "SNAP IN" NEW PART OR DO I NEED TO DO SOLDERING AND HAVE TESTING EQUIPMENT AND SPECIFIC TV REPAIR KNOWLEDGE???
THANK YOU! KURT
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Multiple problems, hoping for one solution
sounds like it is probably worth trying to degauss check this excellent site; http://woil.ws/fixmonitor/ for details of how to try this on the cheap - it works If it doesnt solve your problem, the fact that you are getting different quality from different crt s suggests that they could be the root cause - see if you can get the part number, and get a price you may find it is cheap enough to be worth trying - check also the power supply - poor voltage output can sometimes cause these type of symptoms. Hope this helps, if not post again - some of the other guys know tvs much better than me :)
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
