My canon power shot sd 850 the screen is black and I can't get the view of the pic that I'm trying to take. It shows a red +1/3 on the left of the screen 2nd down from the top. What can I do to get the view back?
SOURCE: Hi I need to get
Set the image size (L, M1, M2, M3, S, PostCard) to PostCard. Then, in the Rec. menu, set the DateStamp setting to either "Date" or "Date & Time".
SOURCE: camra dosent show pic
Please see similar problem titled "black screen". Welsbar posted a possible solution as a clarification request. It involves switching your picture mode to TV and changing the shutter speed to 15 seconds, depressing the shutter button for 7 seconds, then opening battery enclosure. Repeat as necessary - I did this twice before I started to see anything on the screen. Twice more before photos start to look okay. Don't know yet if this is a lasting solution, but at least now I can start using the camera again and find out!
According to Welsbar, the problem is an internal part (iris?) that gets stuck when camera hasn't been used frequently.
SOURCE: Canon power shot won't upload pics. "Cannot connect to device."
It's very hard to troubleshoot software problems online, and it likely is a software issue. But why put up with the headaches of bad software in the first place? Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
SOURCE: Canon SD1000 display is black while the camera in shot mode
After some inspecting of the camera it seen the issue lies with the lens, not the camera itself so don't go banging the camera up or you might damage some other part and the camera will be broken for real. Inside the lens is a closer which block the internal system from capturing image. The closer look just like the one you see before turning on your camera but it's smaller and it's inside the lens way in the far back. Look carefully and you'll see it - you will see the closer if your screen is black while in capture mode otherwise you will see a nice round glass (the internal lens for capturing image/video).
Think of if like this, imagine an eyeball with its eyelid close. That's what happened when the screen is black while in capturing mode.
HOW TO FIX IT: In order to fix the black screen while in capture mode and cost as little damage to your camera as possible, simply turn on the camera in either picture or video mode and look inside your lens, there should be a closer in the far back end. Gently hit the lens a few times until you don't see the closer no more and only a round glass and your camera should begins capturing image and video again.
Good luck to you all. And remember don't use anger to force your camera to works or you will regret it.
If you need further help, contact me via email y a j y e e (at) h o t m a i l (dot) com
Yee Yang
Canon PowerShot SD1000
