Dell Inspiron 530s Desktop Computer   Logo
A
Anonymous Posted on May 21, 2010
I have a black screen after I have entered my windows password. I can see a the mouse moving around but no desktop
Frank Zabroski
Level 2:
Sergeant:
  • Expert 268 Answers
  • Posted on May 25, 2010
Frank Zabroski
Expert
Level 2:
Sergeant:
Answers
268
Questions
Helped
70491
Points
685
You may be a victim of spyware/maleware infections. You will need to have your system cleaned. This should help resolve your issue, but remember you will need to try safe mod for repairs.
I would recommend trying CCleaner first to see if this helps you. Please keep in mind this will not rid your
system of everything just keep you a float and offer you a fighting chance.
Please keep me posted and updated on your issue. I am here for you and will see your issues out till resolved.
Have a great and wonderful day :)
Thank You
Please do not hesitate to contact support :)
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
http://www.itsupport.co.cc
How do i deliet my password form pc windows 8
  1. Swipe in from the right edge of the screen, and then tap Search.
    (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click Search.)
  2. Enter sign, and then tap or click Change sign-in options.
  3. Choose the sign-in option you'd like to use, and then follow the instructions.
For More Information :
https://support.microsoft.com/en-us/help/14064/windows-8-sign-in-to-windows-without-password
Enter system password
Which operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
or
Click "Start," then select "Run." In the text box displayed, enter "control userpasswords2" and press "Enter." This opens a configuration window.
Click the user for whom you want to disable the password login.
After selecting the user, remove the check mark labeled "Users must enter a username and password to use this computer."
Click "Apply."
A dialog box will prompt you for the password.
Enter the user's password to authorize the changes and press "OK."
Reboot your Windows XP computer.
When it shows the list of user profiles, click the user whose password was disabled.
You should be able to log in without a password.
Change password
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Forgot k7 admin password
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Forgot my password
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
I forgot my password can I bypass it
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
I can't remember my username and password
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
I forgot the password and i dont know it
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Acer 532h-2806 has a black screen with blue box that says enter current password? I forgot my password there is no way to get into bios or boot up with out my password
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
it will prompt you to enter the new password
enter the new password and the password is changed
hope this helps
LOOKING FOR HDD PASSWORD
why do you need a password you should be able to attempt repair you should only need the password if you have forgotten it
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
now for the password
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
http://www.afreecodec.com/windows/top-windows-software/windows-password-recovery-software-49067.html
Data Doctor Password unmask unhide program is a useful free utility to reveal passwords hidden behind the asterisk ***** characters inside any protected password text box
hope this helps
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
