Kenwood KRF-V8090D Amplifier is displaying the error message, which on page 58 of manual states, that the 'Cause' is that the 'Speaker cords are short-circuited' and the 'Remedy' is to 'eliminate the short-circuiting'.
I have disconnected all the speaker connections, the sub and even the FM antenna, but I am still getting the 'Standby indicator light blinking' when the unit is switched on.
I have also tried 'Resetting the Microcomputer' and plugging into another power point, but no luck.
Any suggestions?
Hi fuxsiloh.
It sounds like you have eliminated all the things that could generate this symptom that are external to the amp. It is most likely that there is an internal problem that is causing the amp to go to protection mode. A power supply failure(maybe a fuse) is the only really user serviceable part inside the amp. Perhaps check for failed fuses, replacing any that may have blown with exactly the same type. BE SURE TO UNPLUG AT THE WALL FIRST:)
Is the amp still under warranty? If so, then returning it to a Kenwood service center is the shot. If you want to have a go at repairing it, I can talk you through it, but some experience with this sort of thing is very necessary. Good luck
regards
Graeme
Hello I have a Kenwood VR-409 with the same problem. I disconnected everything, tried to reset, but every time I push the power button it breifly comes on than goes off and blinks. I also noted the the MUTE indicator light shows on the panel, I never use the mute and don't know how or why it is showing..
