When you connect the device works it has power but does not read codes
Have you properly programmed the scanner? Are you sure the codes you are scanning are readable and are programmed as active in the scanner? Is the scanner set up to communicate properly with your PC/other device? I'd review the User's Guide and follow their instructions. Here's a link to the guide. Choose the first User's Guide on the list. Good luck
http://www.honeywellaidc.com/Site.aspx/na/en/product_center/product_support/?category=5&product=297
11864, 10054, 10030, 10171, 10020, 10028, 10065, 10096, 11314, 11665, 11963
Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
Ok.
