Lexmark X4270 All-In-One InkJet Printer Logo
Posted on Apr 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm trying to scan and it says check phone line connection.
I don't even have a land line, I use my cell phone. I only use this device to scan and copy. It has been working phone, then all of a sudden it says check phone line connection, which I don't have. I have powered off, then on, even unplugged and plugged back in. Please help.
  • catomaine Apr 05, 2008
    I MEANT to say it has been working fine, not phone. Duh.
    Never mind, I figured it out. I had unplugged the receiver a while back and the scanner had been working fine. I just plugged it back in for the heck of it and now the scanner works. Weird.
Clara Lago
Level 3:
Master:
  • Master 443 Answers
  • Posted on Nov 11, 2016
Clara Lago
Master
Level 3:
Master:
Answers
443
Questions
Helped
179561
Points
2458
I use LEO Privacy to scan my phone. It gives my phone privacy an all-round protection. Why not have a try? LEO Privacy Applock Boost Hide Android Apps on Google Play
  • Anonymous Nov 17, 2016
    Privacy scan really good, I use it to see how dangerous my privacy is. And use it to optimize my privacy.
Anand Kumar
Level 3:
Genius:
  • Master 2,035 Answers
  • Posted on Apr 14, 2008
Anand Kumar
Master
Level 3:
Genius:
Answers
2035
Questions
Helped
852150
Points
5335
Try to clear the memory of the or the printer is in fax mode please choose copy or scan mode
I'm not using a land line with my Panasonic KX-TGD560 and only have my cell connected to it via Bluetooth. How do I clear the "Check Tel Line" message since I'm not using a "Tel Line"?
Check Tel Line means that the phone is not getting a dial tone. Unless you connect the KX-TGD560 base to a RJ-11 phone cord going to a RJ-11 jack with a working telephone service, this message will continue.
I've never used the cell phone link without having a land line connection. The Link-to-cell option for using the handset on Cell 1 (or Cell 2) may still work. You need to have a compatible cell phone close to the base. The phone needs to be positioned where it gets good signal strength. Test this yourself.
I hope this helps.
(Panasonic has the manuals and a trouble-shooting guide for the KX-TGD560 here: http://eng-ca.faq.panasonic.com/app/answers/detail/a_id/55826/~/product-guide---telephone---cordless---model-kx-tgd560%2C-kx-tgd562%2C-kx-tgd563%2C . )
My bt4500 is lit up but won't work
that is not HP device,
why not tell what all that is in front of you.
my guess is this device is a home phone connected to land lines.
right? and is acting up and is not HP at all.
have you tested the land line yet with a real old fashion phone?
to see if the land line is even working?, that be first.
we call that a buttt-in-kit, in the olden days. of POTS phones
now mostly dead in USA.
2nd bad, hand set batteries.
3rd , base power pack dead.
we are not hp,
the real HP is here. 100% real, not fake like most the post on our forum are (spam it is or worse)
here they are, HP
zero hits here on phones.......
https://h30434.www3.hp.com/
the BT means Big button,
not HP
4500-b0pilnzm3b4ny2niuscuwyd1-5-0.jpg the words HP do not show up here
Can I use a land line phone with an answering machine and still use verizon's land line answering service?
Can you not control it by setting the number of rings before answering very high on the device you DO NOT want picking up the call?
No dial tone
indicates that the phones are faulty
the land line carries adsl and phone at different frequencies so as the internet is working so the land line is good
check that the internet and phone line is connected into the correct sockets on the line splitter before the land line connection
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
I have n 95 china phone i need to use internet connection
You can go on internet via your service provider or if you have an ADSL modem,you can use the WiFi facility on the phone.If you don`t have ADSL,speak to your local land line provider for an ADSL subscription.Nice and handy to have a system like that.You can go on the internet from anywhere in your house or bed,day or night and it costs you only land line subscription.
Constant static and noise on the cordless, have not had this problem with other phones in the same location. I have tried the frequency scan- no difference. The noise is so bad the cordless cannot be used.
The main causes of Hissing Noise on phone line
* Weather:
Precipitation can leak into phone lines and cause disruptions. Lightning, even at a distance, can damage the connection.
Checked the connections the cable and the Sockets
If you have the Test socket or the First Socket where the Telephone is is entering .. check the Connections there
* Electrical interference:
Check the Power lines,
Check radio or television transmitters, transformers and other electronic devices may causing noise on the phone line.
* Other phone devices:
Check for the Connection to the FAX check by unpluging the FAX Machine or answering machines,
Disconnect the other phones and line splitters --
Disconnect the Splitters or devices that allow two phones to fit on one phone jack -- can cause phone line noise.
* DSL services:
The high-frequency signals coming from DSL (digital subscriber line) devices sharing the phone line can create problems for other technology connected to the line.
Note : high-frequency signals coming from DSL helps for FAST Internet Connection speed which sometime cause the problem to the Phone or Voice signals for this need to contact to ISP to check the Voice margin .. that may effect your internet Speed
IF the above wont work..
You can try keeping the device near Heater .. it could be the Moisture which might causing this issue
or
Show the Device to the Service provider to repair it
Can I use Bluetooth headset on Bluetooth enabled land-line phone?
Sorry sir those over the head are the only ones to date that i know of
See:http://www.testfreaks.com/blog/review/vtech-ls6245-cordless-phone-with-bluetooth/. Looks like you could at least with this one. I am also looking to do the same.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
