Canon BGE6 Battery Grip (3894502) for EOS 5D Mark II Digital SLR Camera +  LPE6 Battery + Accessory Kit Logo
Posted on May 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Attach strap to canon BG-E6 and 5D
Attach hand strap to canon 5D mark II with Canon BG-E6 battery Grip
Anonymous
Level 2:
  • Expert 178 Answers
  • Posted on Jul 02, 2010
Anonymous
Expert
Level 2:
Answers
178
Questions
0
Helped
45449
Points
477
Canon BG-E4 MANUAL
Recommend contacting your local service provider directly or online here:
Canon BG-E4 MANUAL
Contact Us
Hi, i have a canon 5D mark 11 camera with a velo battery grip. It is 2 years old but over the last couple of days, the camera will not turn off when i use either the on/off body button or on/off grip...
Most definitely battery grip. Prone to a phenomenon know as 'flexing'. The contacts on the grip fail to connect to camera's contacts. Can cause other problems such as switching on and off when you least expect it. I got sick of going thru about two grips for every camera so went with 1D/1Ds series. You'll hear people say 'stick with Canon grips' blahhh(!) too ****** expensive and are prone to the same problem. Can't be helped when you hand hold a camera+grip for long periods - the warmth of your hands can heat up (warp) the plastics and it's all held 'together' by one little screw in a tripod mount (!)
You could 'try' removing the grip, leave it off for say a week. I don't know why it's how, but if always works like new when you put it on again. Until....it starts playing up again. :)
OEM, 3RD party... OTY. For the price of one Canon I could get two cheapies. Always had the 1D (classic) and ahem...still have it! So I stuck with the series (1D IV, 1Ds2) Still holding onto my 7D w/grip (3rd party) though.
1helpful
I have a Canon battery grip for my Canon EOS 300D but have no manual to tell me how to use it as the camera is 2nd hand, can i get a manulal or download one from anywhere
I understand there isn't a manual, just a quick how-to guide. Here's some basic use info from a review
http://www.the-digital-picture.com/reviews/canon-bg-e6-battery-grip-review.aspx
The Canon BG-E6 Battery Grip is designed specifically for the Canon EOS 5D Mark II as shown above with a Canon EF 16-35mm f/2.8 L II USM Lens mounted. To get the Canon BG-E6 Battery Grip into the position shown, the LP-E6 Battery is removed from the 5D II and the battery door detaches. The BG-E6 slides up into the battery compartment and locks into place via the tripod socket screw seen on the BG-E6 just below the lens in the above image. The BG-E6 provides its own tripod adapter threads - this functionality is not lost.
The Canon BG-E6 Battery Grip holds two Canon LP-E6 Batteries that deliver double the number of shots or video time from the 5D II. Alternatively, use 6 AA batteries in the included Canon BGM-E6 Battery Magazine shown below.
I just bought a battery grip for my canon camera. but the grip ceases when i am using it for work. please help find solution
Is this battery grip a Canon or aftermarket accessory? Have you mounted the camera to a tripod if so what lens do you have on the camera? Are you using the adapter for the use of AA's or are you using the LP-E8 battery pack? Are you using the camera in portrait position or landscape?
Here is why Canon has had in the past some problems with battery grips but I thought it was a solved issue maybe not on the entry level DSLR's. What happens is there is enough flex between the body and the grip to break connection and yes it seizes up. Most Rebels will have a plastic lens mounting flange which will also flex with the weight of a lens (longer focal lengths). Also with the longer focal length lens it has more a tendency to flex the battery grip if mounted on a tripod. Holding in the portrait position the weight of the camera is actually pulling away from the contacts so there is a whole series of little possibilities. If it's a Canon accessory then it's a warranty thing if it's aftermarket Humm not sure should have something on it but, the quick fix is to keep tightening the mounting screw/wheel. I know that wasn't the fix you wanted but hey just telling the way it is.
2helpful
Can't control shutter speed
Well you can get the Canon Battery Grip For EOS-40D/30D/20D Model# BG-E2N, which has a separate set of controls including the wheel. OEM is about $170 Chinese clones $80. The camera body will probably sell for about $200 as is on eBay.
Canon 400D won't power up...
hi
a number of new generation devices suffer from DOA (or early death)
often stuff happens on the first day or shortly after
thats where warranty comes in handy
return to vendor and replacement usually is offered without question
otherwise run a multimeter over the batteries and see if they have discharged themselves or failed
D
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
