E-Machines M5310 PC Notebook Logo
Posted on Apr 05, 2008
When you turn it on nothing happens
I have a e machines m5310 that a couple of years ago qiute and we decided to get it out again. When you push the power button everything lights up but nothing happpens. No sound no picture but the cd drive sometimes works. And yes i have plugged it into an external monitor what should i do
  • busman1977 Apr 06, 2008
    Im not sure i dont know much about computers either
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Apr 05, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
748
Points
5
I just bought a lap top and no nothing about them it is a hp compaz nx 5000 I turned it on and the screen is still black don't know how and where to turn the monitor on
My Dryer will not turn on. I push the Power button and nothing happens. The dryer is getting power as the interior light still comes on. My washing machine leaks copious amounts of water during the wash...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
4answers
HI,
I strongly suggest you to replace it with a new battery.
20helpful
I started at the edge of fabric but ended off the fabric.Now E-1.
Check the bobbin area to be sure there aren't any thread tangles that may be causing the jam.
Take it back to the dealer and show them what is happening.
It sounds like the timing might need adjusting.
1991 Toyota SR5 won't start when the weather is very hot
I checked the gages of the wiring which went into the battery, as suggested by another person on the site, but nothing looked out of place. I then proceeded to check wiring connections throughout the vehicle and found there were 2 sets of wires on the driver's side which were not attached to its counterpart. I remember the mechanics disconnecting those a few years ago, as they stated it was causing the problem. I decided to re-establish the connection for both sets of wires and the truck started immediately with out any further problems.
1helpful
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
Won't power up
Did you install correctly the cables?
Did you move any card or memory?
Check it out again!!
The fan of the motherboard is working?
Hit the reset buttom and see what happen
If doesn't work is a bad motherboard
2answers
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. [email protected]
2answers
Need help fixing
I had the same problem a couple years ago with mine. After letting it set for several months, I tried to plug it in again after moving into another house. All of a sudden, it started working again. That was 1 year ago, but just last week...it did it again. I noticed that it does this if it is left on for an extended amount of time (my wife goes to bed at night and leaves it on). I cannot find anything on how to fix it, and no warranty assistance from RCA. I'm purchasing a Sony today, but will hold onto the RCA in case it decides to work again.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
