Hello,he "dl" error code indicates a problem with the door latch assembly.There should be a tech sheet inside the washer. It's usually located
behind the bottom panel under the door, or along the inside of the
casing on either the left or right hand side. The tech sheet will have
a list of error codes, procedures on how to perform diagnostics, and
troubleshooting hints. It's strongly recommended that you leave the
tech sheet inside the washer, so you don't lose it.
Repairclinic.com carries the door latch for about $50 and is listed as item number 1094190.
Thanks
