This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool
Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric
Dryer With AccuDry Sensing System. Dry clothes in the time it takes to
wash them. The dryers uses AccelerCare™ technology to work just as fast
as the washer (Up to a 9 lb. load), giving you more time to enjoy all
the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and
automatically stop the cycle when the load is dry, with the AccuDry™
sensor. Reduce overdrying and save time and effort, by not having to
return to the dryer to re-check progress.
Senseon™ Drying System -
Moisture-sensing strips and temperature sensors inside the dryer drum
monitor how fast the load is drying, how hot the air should be and when
clothes are dry. The system automatically stops the cycle to help save
time and prevent overdrying. Senseon™ technology safely dries clothes
faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle
Shield™ Plus option automatically tumbles the load without heat to help
prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its
front-load washers and dryers to help reduce bending, stooping, or
arching. Based on your height and laundry room needs, optional 10 in.
and 15.5 in. pedestals make loading, unloading, and filling the
dispensers easier. The 15.5 in. pedestal doubles as a storage drawer
with a convenient sliding shelf to support your laundry basket.
Item Features:
- Super Capacity Plus - 7.0 Cu. Ft.
- AccuDry™ Sensor
- Senseon™ Drying System
- 8 Automatic Cycles
- Bulky Items Cycle
- Adjustable End-of-Cycle Signal
- Wrinkle Shield™ Plus Feature (120 Min.)
- 5 Temperature Selections
- Quiet Dry Plus Noise Reduction
- Dry Rack
- Reversible Side-Swing Door
- Dryer Door Window
- Reversible Side Swing Door
- Electronic Controls
- Front-Mounted Lint Screen
- Interior Drum Light
- 4-Way Venting
- Porcelain SpillGuard™ Top
- Optional Storage Pedestals Available
- Stackable Installation with Matching Washer
- Matches Duet® Washer
Specs:
- Warranty: 1 Year Parts & Labor
- Capacity: 7.0 Cu. Ft.
- Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
- Construction: Front Access, Reversible Side-Swing Door
Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount
Lint Screen, Power Cord & Venting Accessories, Stackable
- Controls: Electronic Controls
- Electrical Requirements: 30 Ampere, 120/240 Volts, 60
Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR
THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE
OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Recently purchased a gently used Whirlpool Duet Dryer. Upon my first attempt to dry clothes..realized that it does not heat at all. Have tried unplugging from the wall to reset and have been very patient with the sensors..nonetheless, no heat at all. Whats the problem?
