Probably your system has been corrupted, or you have installed a software that caused your system not to function due to conflicts.
The solution that i find to solve your problem is to perform windows xp repair install, which will replace corrupted files on your system in order for you system to run properly.
Follow these step by step solution on how to perform the Windows XP Repair Install.
You should first check if you have these on your system.
1. A CD/DVD Drive.
2. A bootable Windows XP Install disk, depends on the version of your Windows XP , whether it be SP3 or SP2.
3.Idea on how to boot to your BIOS settings, you can check it using your systems manual or you should see a press button (e.g "Press F2 to SETUP").
Step by step solution on performing Windows XP Repair Install.
1. Insert the Windows XP installer on your CD/DVD Drive.
2. Restart your system.
3. Go to your BIOS Settings and set your CD/DVD drive boot priority. We will be booting to your Windows XP Install disk to perform reinstall on your system.
* Reinstalling doesnt affect your programs, but will just delete the previous windows xp system files and replace it with a new one.
4. When you are now in the Windows XP Install screen where you can select if you want to install windows xp, go to windows repair console or exit the installation. You should select "to Setup windows XP now press Enter".
Heres the screenshot as a guide.
Press Enter, then when you see Searching for previous windows installation, you should select "R" to repair your installation, if you dont see any "searching for previous windows installation message" then you should check your bios settings.
After the reboot, you should set back again your BIOS to boot from your hard drive. restart your system, also you should prepare a valid windows xp cd key for that because you will be needing it confirm the setup process of your system.
After the reinstallation process, you can now boot your windows xp system nice and clean. :)
setup says there is no HD driver
