Good morning i have kholer generator. problem is that it show UU, UF, and CC, what does its mean plz help me. and what i doo in this situation.theanks ok bye
hello to Brandy
what does turn over mean to you, (me means ZERO)
the words are
cranks fast. or does crank at all
or cranks fast but engine will not start or run or stay running or only runs 1 to 10seconds (IMMO unhappy)
we are blind here and deaf too
we can not hear your starter motor run or fail or be super weak (slow)
sorry no can do
the starter spins (turns)
the engine many spin (turns)
and some people call turns over mean running engines, Turns means zero in the real world lacking qualifiers in the statement , sorry .
Hi Crystal:
My understanding:
"Crank" means turn over under the power of the starter.
"start" means it starts running
If your vehicle will not "crank" I would think that means you may have a bad battery, terminal, or connection, or ignition switch, or solenoid, or starter.
If your vehicle will not start, I would be thinking that it is cranking but won't run, so I would be looking for a spark (ignition) problem, or a fuel delivery problem.
Hope this helps.
Hi Teresa thats ththhe sign of a battery going bad, how old is the battery? You might want to have it load tested so you can trouble shoot further, there could be more than 1 issue.
not crank mean not start or means the crank shaft if locked.
if it cranks, (means crank shaft spins fast in start position)
does it have full compression 150psi.
the if that is ok, next is spark got spark x3
if that is ok and timed right,
then try test fuel , run for 3seconds? now?
IF YES, then its fueling issue.
we dont know what it sounded like before , or now. why not say?
I think you mean it wont run after running out of gas. You may have to remove the spark plug and shoot a small shot of starting fluid in the hole and replace the plug. Cranking means turning the engine with the starter motor.
If the crank sensor circuit is malfunctioning, then that is your problem. The code does not mean that you must replace your crank sensor. (sometimes it means this, sometimes it does not) The code means that either the crank sensor CIRCUIT is out of range or the crank sensor cannot SYNCRONIZE with the cam sensor. There is a whole lot more to diagnosing a crank sensor circuit than simply replacing the crank sensor. Proper diagnostic procedures need to be followed to locate the exact cause of the problem.
turn over and crank, mean the same thing. do you mean will not crank? or cranks but wont run? it could be anything. you need to figure out "if" it does crank, but wont run, is it missing spark or fuel?
Hi, there.
Did you mean, It is crank But not START?
If your car is not crank at all, it is mean you need to check :
- power line
- relay / solenoid
If car crank but not start, it is mean your need to check :
- fuel line
- ignition
-vacuum leak
- EGR etc.
So , please check your car to get where the root cause is and get it fixed quickly.
Best regards, Jay
Crank means turn over.Do you mean that it is cranking but not starting?If so then make sure you have spark to the plugs.If spark is good then see if you have fuel pressure.You have to find out if you are not getting spark or fuel.Hope this helps.
