My blackberry 8520 cure app error 523
1. Install the software Desktop Manager
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common
Files\Research In Motion\AppLoader
3. Open Desktop Manager
4. Connect Curve 8520
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System
6. During the process, select YES to do a backup
7. The whole process should take about 1 hour
I want to remove java.lang.error
SOURCE: BlackBerry Curve 8520 Smartphone: when i turn on my blackberry curve 8520 it has a b...
just re install the blackberry operatind system software into ur fon from ur computer................and go on ....................or u can take off the battery and put it into again and press the return key when the red light goes off and till ur cell completly opens dont leave the return key..............it opens ur cell in safemode and u can deal with the error in safe mode
SOURCE: how to correct app error 532 for blackberry curve
download a BB desktop manager ,install it and then connect your phone to the pc via the cable ,let the pc install the drivers o the phone be patient , your desktop manager will recognize your phone , there is one option name update device ,click on that and follow the instructions ur phone will be updated online and your prob will be solved , if u still need assistance mail me at [email protected]
SOURCE: my blackberry cure 8520 Smartphone
Thanks for visiting FixYa!
You may be able to solve the problem you're having with your phone yourself. There is an amateur video on YouTube that shows the procedure. Although the video was made by a kid, it has some good information. (See below)
The problem is usually caused by an application that has become unstable and needs to be removed. To do this properly, you're going to need to reinstall the firmware on your phone. This may take up to 45 minutes. Important: Make sure your battery is FULLY CHARGED before beginning the procedure. And, DO NOT unplug your phone or turn it off during the reinstall.
You'll also need the Blackberry Desktop Manager if you don't already have the software on your computer.
PC Download: http://us.blackberry.com/apps-software/desktop/system_requirements.jsp
Mac Download: http://us.blackberry.com/apps-software/desktop/desktop_mac.jsp
Testimonial: "perfect steps for solution of OS"
