Okay this is whats up. i got this camcorder from a friend and don't want to buy taps to record with. I have an SD card in the GR-D770. how do i make the camra record directly onto the sd card and not a tape?
Check to make sure the type of SD. card matches what the maufacturer calls for. Also the SD card may need to be formatted before you can record to it. Check your intruction manual to find out how to format the card. One last thing to check is if the SD card is locked. Usually on one of the corners there is a sliding tab used to protect and unprotect against recording over any material that may be on the card. Hope this helps.
you should check out your sd card whether it has virus or not or you may try to format you card.I think it may help you.... if not let me know i'll give you other solutions.
You may not have that option.Most camcorders give you the option to either record to the built in memory or the SD card Flash Memory.The option to copy from the internal to SD card is device option. You can use USB, AV , cables to convert files to DVD or other formats to copy to Flash Media or DVD/ VCD/DVD RAM.Good Luck.
Hi, look here's what to do, get yourself, or access to, A Computer, and a USB SD card reader, now, insert your 8GB SD card into the reader/writer, It will show up as a HDD in My Computer, and then, Format it FAT32. Now return it to the Camcorder, when turned on again, the Camera NOW should "See" the SD card. You may even be asked if you wish to Format,again,say YES, and do so, if NOT asked that;s OK too. as, you should now be able to, in either case, be able to have access to the SD card, and can change your phone settings accordingly, the extra storage will simply be "Picked Up" by the Camcorders software.
If this doesn't happen, then there maybe a problem with THAT SD card or the Camcorder? try another SD card before thinking the camcorder has a problem though.
Sorry, but as far as I know, Hitachi camcorders cannot record video directly onto an SD card. You have to set the camcorder to DVD. It can only record video and pictures on a DVD, and only pictures on an SD card.
It can capture still images to SD or MM card. SD or MMC removable memory
card. Depending on the compression and the selected resolution, the
camcorder can record 220-880 JPEG images on a 32MB memory card or
45-190 on 8MB of memory.
