Oe is drain error, which means that the machine is slow/or not emptying..Most likely you have to clean the pump filter...This is accessed via the small door at floor level..Unscrew the pump cover andclean the filter...Remember that any water will drain from the machine from here, unless the machine is empty...Leaning the machine back can help...Good luck...Nomess
