Question about Canon FAX-JX200
CANON FAX JX200
HELLO, I CHANGED THE INK CARTRIDGE ON THIS MACHINE TODAY,
AND NOW THE ERROR MESSAGE READS "!!!CHECK !!! 5100
CAN YOU TELL ME WHAT THE PROBLEM MIGHT BE? THANK YOU.
  • 7 more comments
  • DAWNDEMOSS Apr 04, 2008
    THANK YOU, MIKEZIADEH. I DID REMOVE THE CARTRIDGE, BUT THE ERROR MESSAGE CONTINUES. I'VE UNPLUGGED AND RE-PLUGGED THE FAX BUT TO NO AVAIL. THANKS, ANYWAY!
  • office114 Sep 15, 2008
    I have a fax Canon JX-200 - the display shows an error code 5300. Can you help me please?
  • Anonymous Sep 30, 2008
    i have the check 5100 problem, but i cant get the ink cartridge to the correct side to take it out? how can i get it?
  • Beverlina Oct 26, 2008
    I have just plugged in my brand new Canon JX200 and have the CHECK!! 5100 and a flashing light! The manual says it may need a service, but it hasn't done anything yet?! Please are you able to advise?
    Many thanks
  • Anonymous Nov 13, 2008
    THE FAX MACHINE GETS READY AS IF IS GOING TO PRINT AND THE ERROR MESSAGE 5100 COMES ON THE SCREEN.
    THANKS AND HOPE TO HEAR FROM YOU SOON.
  • thompson154 Dec 06, 2008
    I am not even going to accept this type of error response. I just opened a new machine not a refurb and got the Check 5100 . It's going right back to Fry's and moving on. Don't even waist you time with such a piece of junk.
  • badadino Dec 16, 2008
    Hey everybody i'm Badadino From morocco i got Canon Fax JX-200 and some problems within : First The LCD make off every 2 Minutes and when i reboot the machine is good but that give me error in lcd ARRET IMPR AUTO .
    i'm verry thankful if somebody help.
  • artevolve Feb 28, 2009
    i get the same error. I have had many printers and fax machines in the past including ones from samsung ml-1610 - fab, and canon 4200 - good but expensive to run; but this fax-jx200 is the worst machine EVER - does lots of things but NOTHING well. No better than a basic telephone. Will call canon for fix - no doubt will tell me take to a service centre and be ripped off. This has damaged the canon brand in my opinion.
  • vickik88 Mar 24, 2009
    My fax comes up with the 'CHECK 5100" error, I have just put in a new cartridge and I am assuming it is stuck. But I don't know how to get the cartridge back to the other side to where you can change it??
    New Friend:
I fix this problem that way:
1. turn off
2. turn on with open cover
3. while loading cought cartrige in left possition and took it out
4. when complete - thet turn off/on with open cover
4.1 cartrige holder stack in right position then i press again off/on
5. put cartrige back
my fax started printing out errors that something wasnt delivered
Hope my solution helps you
Posted on Jun 11, 2013
K this problem is caused by two things one the cartridge and then a paper error, this is what i did first remove the cartrige then clean the print head with a cloth and some spirits, then put in the cartrige again, ok step one down now, the problem still comes up because the cartrige cause the error now there are still error reports that needs to be printed so, put in paper in to the printing paper feeder and shut down and start up the fax/printer
Posted on Oct 29, 2008
Did you lift the cartridge up to where it was able to clear the paper deck? IIRC 5100 means that the ink carriage is stuck.
Posted on Sep 11, 2008
  • 82 Answers
Remove the cartridge and see if it goes away, if does then you probably have a defective cartridge are are not inserting it correctly.
Thank You,
Mikey
Posted on Apr 04, 2008
6ya staff
SOURCE:
Please send me fax manual for Canon-JX200. message
Please send me an email to LBrown18062@hotmail.com and I will send you the manual right away. Please put CANON FAX JX200 in the subject line and I will send you the manual right away. Lawrence Brown
Oct 24, 2011 | Canon FAX-JX200
Message CHECK 5100!!!
hi; this message appears when the wast ink absorber is full
Oct 14, 2010 | Canon FAX-JX200
Message flashing check CRT
It's telling you that the ink CaRTridge is nearly empty. Replace the ink cartridge.
Mar 10, 2010 | Canon FAX-JX200
Check print 5100
its a carrige lift error!Power down and remove the cartridge !Check for anything that can prevent it from moving up or down proberly!Put the cart back and check what happens!
Mar 02, 2010 | Canon FAX-JX200
Check error 5100 on the display of jx200
Movement of the ink cartridge holder is blocked. There may be a scrap of paper, or staple, or paper clip binding the cartridge from moving. Check for foreign objects. Press and hold the on / off button to power down the fax. Unplug it from the wall outlet for 5 minutes. Plug it back in and power up. Also, check to make sure the cartridge is installed correctly by removing and reinstalling it. If the same error occurs, contact Canon service rep.
Reference page 62 in Users Guide.
Dec 15, 2009 | Canon FAX-JX200
Hi my fax displays the message CHECK 5100
my fax Canon JX201 displays the message CHECK 5100
Jun 26, 2009 | Canon FAX-JX200
Canon jx500, getting 'check 5100'
I had this problem and solved it = )
You turn off the fax, take the paper out, then open the cover just after you turn it back on.
Leave it open for a minute and let the cartridge go back and forward close the cover and wait till it tell you to press stop and it should be back to normal.
Hope this helps
Mar 10, 2009 | Canon FAX-JX200
Canon fax jx200
You need a new ink cartridge
Oct 25, 2008 | Canon FAX-JX200
Canon JX200 - Recomend New Cartridge
no you can't disable the ink monitor, but it sounds like you have a defective or a cartridge that belongs to another machine.
Thank You,
Mikey
Apr 04, 2008 | Office Equipment & Supplies
Canon FAX-JX200 Logo
5,445 people viewed this question
Clive
Clive
old marine
old marine
Ekse
