Samsung Digimax S630 Digital Camera Logo
Posted on Apr 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Buzzing sound when i turn on my camera and turn offf my camera it makes a buzzing noise and when i take a picture its alll blurry
Anonymous
Level 2:
  • Expert 35 Answers
  • Posted on Apr 05, 2008
Anonymous
Expert
Level 2:
Answers
35
Questions
0
Helped
26734
Points
113
The problem is with lens.this sometimes happens if cam becomes victim with water.
there is some buzzing noise when the shutter of lens gets opened or closed.
please clean the lens with the solution once.then you can make out of blurs.
My Olympus Fe-46 digital camera taking blurry pictures and buzzing when I turn it off?
this is a common problem with htc m7 & m8 they use a focus motor and get damage from motorcycle vibration or high shocks. i had the same problem on my m7 and m8, i took the phone to the supplier and i got new one instead.
now am using different phone when riding
When i press the on button camera makes a buzzing sound but does not switch on. previously it has been taking photo's but they are blurry.
Your Camera is either out of battery of uncharged.The buzzing sound is the sound it makes when the camera zooms in,most cameras automaticly do this when started up.The reason for your pictures being blurry,could just be off focused.Hope it helped
2helpful
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Olympus FE 230 Problem
I had the same problem. I hit it a long time ago when it did it for the first time. It has been a year since then and it is doing it again. I tried the book solution again and it will not work. I tried holding the lens, no luck, and I tried applying pressure when the lens went back in, again, no luck. Honestly, I don't think I will buy another Olympus fe series camera again. The solutions provided do help the first few times your camera does it, but you might want to start checking the market for a new camera.
Finepix A350 - everything is blurry
I had the same problem. I tried a reset in the camera, also reformated the card through the camera once I had done a reset. At present it seems ok.
1helpful
The lens is blurry and makes a buzzing noise when turned on
Well all the moving parts of the lent are plastic and most likely the reason Y you hear that sound it's because one of the hummmm the tiny wheels , that are connected to the mechanism of the focus on the lent is busted..... so replace that.
(some times if you take the camera to the beach the sand get to the mechanism ans stock the wells. In that case cleaning of the lent will suffice)
Now parts are not that easy to find some times companys only sale the complete lent and it will cost you, in that case you will need to decide if "REPAIR" or "BUY NEW" camera will be better
Blurry pictures!! help!
If it's making noise when turned on you are experiencing trouble with the lens. If you send it into repairs they can fix that. Give them a call at 800-706-2534 option 2.
Very poor picture and blurry lcd screen
mine is doing the exact same thing and i don't understand why because it started when i tried to clean the lens. let me know if anyone helps you with this problem, please.
[email protected]
thanks!
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
