Toshiba Satellite L45-S7409 Notebook PC Logo
A
Anonymous Posted on May 20, 2010
Lost password to the bios... - Toshiba Satellite L45-S7409 Notebook PC
Anonymous
Level 1:
Novelist:
  • Contributor 60 Answers
  • Posted on Jun 08, 2010
Anonymous
Contributor
Level 1:
Novelist:
Answers
60
Questions
0
Helped
70115
Points
83
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
How do I change my admin password
admin windows
admin BIOS
we can not guess,
we can not see your screen so,can only beg.
LOST?
  • bought it dead.
  • kids wrecked moms PC
  • out of the blue asks now but not before.
  • forgot it.
if not lost the , BIOS password are in bios page named that.
if not lost in windows, click control panel , click users, bingo.
1helpful
Dell vostro a860 bios password
The best method to reset a BIOS password depends on what BIOS the computer has. Common BIOS's include AMI, Award, IBM and Phoenix. Numerous other BIOS's do exist, but these are the most common.
Some BIOS's allow you to require a password be entered before the system will boot. Some BIOS's allow you to require a password to be entered before the BIOS setup may be accessed.
The general categories of solutions to reset a BIOS password are:
* Using a Backdoor BIOS Password
* Resetting the BIOS Password using Software
* Resetting the BIOS Password using Hardware
* Vendor Specific Solutions for resetting the BIOS Password
Some BIOS manufacturers implement a backdoor password. The backdoor password is a BIOS password that works, no matter what the user sets the BIOS password to. These passwords are typically used for testing and maintenance. Manufacturers typically change the backdoor BIOS passwords from time to time.
AMI Backdoor BIOS Passwords
Reported AMI backdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords
One reported Award backdoor BIOS password is eight spaces. Other reported Award backdoor BIOS passwords include 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords
Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
Backdoor BIOS Passwords from Other Manufacturers
Reported BIOS backdoor passwords for other manufacturers include:
Manufacturer BIOS Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
SOYO SY_MB
TMC BIGO
Toshiba Toshiba
Remember that what you see listed may not be the actual backdoor BIOS password, this BIOS password may simply have the same checksum as the real backdoor BIOS password. For Award BIOS, this checksum is stored at F000:EC60.
Every system must store the BIOS password information somewhere. If you are able to access the machine after it has been booted successfully, you may be able to view the BIOS password. You must know the memory address where the BIOS password is stored, and the format in which the BIOS password is stored. Or, you must have a program that knows these things.
You can write your own program to read the BIOS password from the CMOS memory on a PC by writing the address of the byte of CMOS memory that you wish to read in port 0x370, and then reading the contents of port 0x371.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
* ACER/IBM BIOS
* AMI BIOS
* AMI WinBIOS 2.5
* Award 4.5x/4.6x/6.0
* Compaq (1992)
* Compaq (New version)
* IBM (PS/2, Activa, Thinkpad)
* Packard Bell
* Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
* Phoenix 4 release 6 (User)
* Gateway Solo - Phoenix 4.0 release 6
* Toshiba
* Zenith AMI
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
RTC's which require external batteries include:
* Dallas Semiconductor DS12885S
* TI benchmarq bq3258S
* Motorola MC146818AP
* Hitachi HD146818AP
* Samsung KS82C6818A
Most RTC chips with integrated batteries can be reset to clear the BIOS password by shorting two pins together for a few seconds.
You will see more than one option for some chips due to testing by various people in the field. Remember to remove power from the system before shorting these pins.
RTC Chip Pins
Dallas DS1287A
TI benchmarq bp3287AMT 3 (N.C.) and 21 (NC/RCL)
Chips & Technologies P82C206 12 (GND) and 32 (5V)
-or-
74 (GND) and 75 (5V)
OPTi F82C206 3 and 26
Dallas Semiconductor DS12887A 3 (N.C.) and 21 (RCLR)
You should be able to discover how to reset the BIOS password stored in most RTC (Real Time Clock) chips by reading the manufacturers data sheet for that RTC. Some RTC's, like the Dallas DS1287 and TI benchmarq bq3287mt cannot be cleared. The solution to resetting the BIOS password on systems with those RTC's is to purchase a replacement RTC chip. How inconvenient!
2helpful
Actius AV18 (PC-AV18) PC Notebook: lost bios password...
Just visit this or click here
Enter your model and hash code and they email back your bios master password for your Laptop/computer.
2helpful
How do i reset the bios password
How to recover your forgotten laptop BIOS password? There are 3 methods, each method has its strength and weakness but I am going to talk about the 2 easy methods that works across the board for everyone. Here they are:
Method 1 – Remove BatteryFor desktop user, open up your computer casing and look for the battery. Remove the battery for approximately 5 minutes (maybe longer, depending on the motherboard) and slot it back. By removing the battery and deprive the motherboard’s flash memory of power supply, you are essentially resetting the settings back to default when the existing data in BIOS are cleared.
laptop_battery_desktop_bios_remove_reset.jpgThis method works well for desktop, however this is not practical for laptop user unless the warranty expired long time ago. This method might or not not work, it depends on the type of motherboard.
Method 2 – Reset CMOS With SoftwarePC CMOS Cleaner is the best CMOS password reset software, it works setting the BIOS to the default state or revealing the password.
reset_bios_cmos_password_motherboard_remove.jpgreset_bios_cmos_password_motherboard_remove2.jpgPC CMOS Cleaner is an easy-to-use tool to recover, delete, decode and display the superior passwords stored in BIOS whatever the brand is. Most types of BIOS are supported. It’s an bootable CD that runs on x86 and x86_64 computers. No need to pay expensive fees to experts. It’s a useful tool for users to get their lost BIOS password back, or clean passwords from an old computer bought from others.
  • Support all x86, x86_64 Personal Computers.
  • Support most BIOS, such as: AWARD, AMI, Compaq, Phoenix, Samsung, IBM, Compaq, DTK, Thinkpad, Sony, Toshiba and so on.
  • Display the superior passwords of the BIOS .
  • Remove BIOS password(will set the BIOS to default status, need reset date).
  • Set the BIOS to default state
3helpful
3answers
Forgotten Password
Most methods can be introduced online. But for if you want lost your data and also can reset effectively and quickly Anmosoft Windows Password Reset will be the good method. It is reset software and can allow you to reset or change your password, or create a new account. And also it can reset the admin password or other account passwords.
Lost bios password
short the pins of BIOS start the machine then again start the machine in normal mode.
BIOS password lost
Here is a link to the User Guide:
CUSL2-M User Guide
Save a copy to your HDD.
The procedure for resetting the password is on page 57.
2answers
Lost BIOS Password
ulta ho ke gand de de
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
