Hi, i have a panasonic KX-T7730 tel connected to a KX-TA308. Its programed so that at nite i press a button (nite mode) and the fax answers automaticaly the i come in the morning and press the day mode button and sets off the fax.
Now the day mode button is not working (says invalid) and i have the fax answering all day.
Basically, there are 2 ways of programming the date and time - the short way and the long way. If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system:
SHORT WAY: From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook: 1. Press PROGRAM 0 2. Enter Date and Time ( The format is: yymmdd, 1 to 7 1=Monday 2=Tuesday etc, hh:mm, 0 or 1 0=AM 1=PM ) see example 3. Press AUTO DIAL / STORE to save your changes 4. Press PROGRAM to exit program mode
EXAMPLE: If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows: 100203 2 02:15 1
LONG WAY: From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook: 1. Press PROGRAM * # followed by the system password ( default is 1234). 2. Now press 000 and then SP-PHONE. Enter the year. 3. Scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. 4. Now scroll right again and change the date and day. To change the day, again use AUTO ANS / MUTE 5. Scroll right again and the time will appear. Set the time. To change am/pm scroll to it, and again, use the AUTO ANS / MUTE button. 6. Press PROGRAM to exit program mode and you are done.
LONG WAY: From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook: 1. Press PROGRAM * # followed by the system password ( default is 1234). 2. Now press 000 and then SP-PHONE. Enter the year. 3. Scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. 4. Now scroll right again and change the date and day. To change the day, again use AUTO ANS / MUTE 5. Scroll right again and the time will appear. Set the time. To change am/pm scroll to it, and again, use the AUTO ANS / MUTE button. 6. Press PROGRAM to exit program mode and you are done.
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode. PLEASE vote if this was helpful
With the handset on the cradle press Program * # followed by the system
password ( default is 1234). Now press 000 and then Sp-Phone.Enter the
year and then scroll to the month with the right scroll key (located at
ANS / MUTE button. Now scroll right again and change the date and day.
To change the day again use the AUTO ANS / MUTE button. Now scroll
scroll to it and again use the AUTO ANS / MUTE button. Press program to
exit program mode and your done. Please rate this answer if it was helpfull Thank you.
If you are using the KX-T7730 phone with a Panasonic KX-Txx 308/616/824 system. From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done. Please rate this answer if it was helpfull. Thank you.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/616/824 system. From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done. Please rate this answer if it was helpfull. Thank you.
If you are using the KX-T7730 phone on a Panasonic 308/616/824 system. From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done. Please rate this answer if it was helpfull. Thank you.
