SOURCE: DVD XV-S302
hi what is the way you are getting the sound to your tv? is it audio video composit cables ? or scart one ? try to get new scart or change between the cables to decide which one is broken try to shake the scart from the side of the tv set it is propably a connection fault !! please don't forget to do excelent rate cause i here to help you regards
SOURCE: Parent control lock
The parent control lock out code is 1234, you need to press yes then enter the code using the remote type in 1234 then press play button again and it unlocks the parent controls!
SOURCE: Parental control password for HM600D DVD Player
The default password is using the FAST FORWARD AND REWIND buttons, it is forward, back forward, back.
SOURCE: automatically lock???
ATTENTION Opening your player will void the warranty! Modification are at your own risk! No guarantee for function!
JVC XV-511
selfmade hack
1. Remove the top cover. 2. Locate wire jumper B532 o the printed circuit board nearby the front panel, it can be found just underneath the connector linking this board with the one above. 3. Cut bridge B532. 4. Apply power, PW (Password) appears on the display. 5. Enter the code 5963 with the remote controller, PW OK will be displayed. 6. Switch the set off and on ... and it will be zonefree !!!
Important information It seems that JVC received some complaints from the software industry that these players were much too easy to modify and they had to change the design to prevent further 'multi-zoning'! All sets with a serial number starting with 134xxxxx or 144xxxxx will normally need a new PROM to make them a real multizone machine! Don't despair if you have one of the newer types because there's a hidden multizone 'backdoor' ! Yes, the above mentioned modification will still work after you plug in the power cord, at this moment the set will play all zones as long as you don't switch it off with the standby button, once this happens it will be back to zone 2 and you'll need to unplug/plug in the power cord again to get it back to multizone. ATTENTION Opening your player will void the warranty! Modification are at your own risk! No guarantee for function!
SOURCE: JVC XV-M555 DVD player has the parental control
Found the manual for the player buried in a box from moving. Procedure is
1) With no DVD in player
2) Press enter while holding down shift to display parental lock menu
3) If you dont remember the password enter 8888 to access the options
4) Use cursor to move arrow to country code option
5) Use right cursor to select country code, then down cursor to move country code to US
6) Use left cursor and down cursor and right cursor to move to set level
7) Use down cursor to toggle through level options. (None removes all blocks)
8) If setting a level toggle down to password and set new 4 digit password.
