Question about Toshiba 50HX81 50" Rear Projection Television
I do not no the pin and it is blocking my access to the v-chip controls
  • Toshiba Master
  • 1,527 Answers
Hello press the recall button 4 times within 5 seconds the blocked status will be released if it don't work i'll send you the owners manual for free good luck
regards
shaun
Posted on May 22, 2010
6ya staff
SOURCE:
Have protron pltv-32cm. model lt32c1m1. how do i shut off the v-chip block? i don't have the password.
Hello, there is a default password, if you source is in component 2 it can't be used here are some links to the pdf file pltv types.
V-Chip Lock When turned on, blocks access to mature television and movie content, based on the MPAA and TV PG ratings selected below, unless the viewer enters a password (set below). Set Password Sets the V-Chip password. To change the password, enter the current password followed by the new password. The factory-default password is '1234'.
PROTRON PLTV 32C User Manual Parental Controls
hope this can help.
Feb 21, 2015 | Protron PLTV-32 Television
Unlock pin on hannspree 22
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Sep 17, 2012 | RCA 24V511T 24" TV
What does jumper j1h3 do
Oh, there it is in the second problem you posted. Intel 945GCZ,
Hmmm, lemme see.................Junction 1 Header 3,
Dunno, the wonderful(?) motherboard manual doesn't state it.
The Southbridge chip is an Intel 82801 (ICH7)
Right next to the 4 SATA connectors. Are talking about that jumper block with 3 pins, next to it?
LEAVE IT ALONE!
That is the BIOS configuration jumper block.
Has three pins. The outline around number 1 pin is a square.
The outlines around pins 2 and 3 are circles.
Pin 1 is towards the outside of the motherboard. Towards the I/O area.
Should be that the jumper block is on Pins 1 and 2, for normal operation.
Jun 24, 2012 | Computers & Internet
I cant reset parental controls
Activated by a PIN number, you can set Parental Controls on your TV and/or cable set-top box to control the programs that can be viewed on your TV. There are three ways to block programs:
  • By Channel
  • By Rating
  • By Time Period (Not available in all areas.)
The V-Chip understands television program ratings and blocks programs based upon the rating level selected. All TV sets that are 13 inches or larger are required to incorporate the V-Chip technology. Parents set rating levels so that certain TV shows need a password to be viewed. For more information on the V-Chip and program ratings visit the FCC V-Chip site.
Several cable and satellite companies offer parental control options. They allow specific channels to be blocked so that they cannot be viewed.These companies also offer the ability to block shows based on language, violence, nudity, and rating levels. This offers more flexibility than the V-Chip.
Hope it helps ;-)
Jan 25, 2011 | Syntax LT20HVK 20 in. HD-Ready LCD...
Some channels are block out using 0000 or 9999 dose not help nee to cancel the c9od that in there, help
1. Select Canada V-Chip from the PARENTAL CONTROL menu.
2. Highlight English Ratings or French Ratings and press OK.
3. Determine the rating you want to block.
4. Press the down arrow button to scroll to the rating you want to change.
5. Press the OK button to change its status to block (the lock icon appears and all ratings above the one you selected change to lock). FRENCH RATINGS Go Back 18+ 16+ 13+ 8+ G
Press OK to view/block programs intended for children over the age of 8. V-Chip Movie Rating Limit Set movie rating limits by blocking movies rated above a specified level.
To access the Movie Rating Limit menu:
1. Press MENU on the remote control (the MAIN MENU appears).
2. Select Parental Control.
3. Select USA V-Chip.
4. Select Movie Ratings. Blocking Movie Ratings Once you are in the Movie Rating Limit menu, follow the same steps described for blocking Canadian V-Chip Ratings.
V-Chip Exempt Program Block The Exempt Prgms. option lets you decide if programs that the V-Chip recognizes as unrated can be viewed. Unrated TV programs may include news, sports, political, religious, local and weather programs, emergency bulletins, public announcements, and programs without ratings. The Exempt option applies to both USA and Canadian unrated programs and Canadian programs rated E. 20 Graphics contained within this publication are for representation only.
Using the TV's Features Unlocked All unrated programs are available. Locked All unrated programs are not available.
Nov 08, 2010 | RCA 27V530T 27" TV
Cannot access system -- forgot password. Cannot
Open the computer case. On the motherboard, (looking from the bottom of the motherboard), in the bottom right quadrant, to the right of the CMOS battery, you'll see two jumpers labeled CLR_CMOS and PSWD. You'll want to move the jumper for the PSWD block to pins 2-3 for 5 seconds and then replace the jumper on pins 1-2. This will clear the CMOS password.
Feb 07, 2010 | Dell Inspiron 530s Desktop Computer
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Forget the flat tv password
These instructions are from the model 25R-S100 but should work for you.
1)Press MENU to access MAIN MENU screen.
2)Press CH UP (8) or DOWN (9) to move the selection to “PARENT CONTROL”.
3)Press VOL (+) or (–) to access PARENT CONTROL mode, then “PARENT CONTROL V-CHIP BLOCK” is displayed.
4)Press and hold both VOL (+) and CH DOWN (9) on the TV set simultaneously until the message “INPUT SECRET No.” disappears.
Aug 29, 2009 | Sharp 25L-S100 25" TV
SDM-S73, no power light, appears dead
it is a chip for voltage control. or... I don't know in english, in romanian it calls it PUNTE REDRESOARE . It change power voltage from alternative in continuous.Look if it comes from trafo .
Jun 07, 2008 | Gateway FPD2275W LCD Monitor
Parental control
1. Go to the V-chip selection in the customer menu.
2. If the set has an active PIN code, the menu will display “BLOCK-ING ACTIVE”.
3. Press RECALL on the remote four times within five seconds.
4. The menu should then display “BLOCKING RESET”.
5. Input a new four-digit PIN code and press ENTER.
6. The next menu page will appear which allows you to scroll down to the various lock selections. If you want to remove the PIN code completely, instead of entering a new code, just exit the menu after pressing recall four times.
1. Disconnect AC power for several seconds to reset unit clock.
2. Adjust unit volume to minimum.
3. Press and hold volume down button on unit control panel.
4. While holding the volume down button, press and hold the “Zero” key on the unit remote.
5. The user menu will appear with the V-Chip cursor blinking.
6. Pressing the “Enter” key on the unit remote will open the “New Password” menu.
Have a great day!!
Bill
Dec 09, 2007 | Toshiba MV13L3 13 in. TV/VCR Combo
Toshiba 50HX81 50" Rear Projection Television Logo
24 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
