The defrost thermostat is not working and the evaporator compartment is blocked with ice. That will stop cold air from entering into the fresh food compartment.
Move your food to another refrigerator, then unplug and open the Samsung refrigerator for 24 hours and allow the ice to melt.
Then remove the freezer panel inside and locate and replace the little plastic tube like part that is zip tied to the expansion tubing. It should have 2 brown wires coming out of the plastic sealed tube/ thermostat part. Write down your model number and go to Samsung's website or searspartsdirect and buy a new thermostat.
I believe the operating range for said thermostat is 20 C to -5 C. you'll most probably have to cut the wires and splice in the new thermostat. You can also use a generic thermostat with the same or nearly the same ratings of 20/-5 C temp.
All the thermostatic switch does is control the defrost heating element that melts the ice off the evaporator every 10 to 12 hour cycle via the defrost timers switch located at the bottom rear of the refrigerator. You can turn the clock counter clock wise until the first loud click to force the machine into defrost as well. Although if the defrost heating element, thermistor, THERMOSTAT, or defrost timer switch has malfunctioned there will not be a defrost cycle and ice will form inside the ducting and evaporator compartment and block the cold air circulation and the fresh food compartment will not cool and the freezer section will barely freeze water.
SOURCE: Samsung RS21w USA style frige freezer panel problem
hold down the 2 lower buttons for 5 seconds to unlock the display panel
SOURCE: FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
SOURCE: Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
SOURCE: Freezer works ref does not
That is your problem the Freezer Fan supplies air for the freezer as well as the refrigerator. If the rpm are not high enough the frig does not get cool. I just replaces this fan and that was the solution
SOURCE: fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
