a chain saw has the oil mixed into the gas if it is not mixed right it will smoke that is the only source of oil to the engine mix up a new batch of fresh fuel and oil mix it will be fine
I put a new bar and chain on my craftsman 18" chainsaw because the chain keeps coming loose. I am still having the same problem, after running 10 seconds, the chain falls off.
Take the bar off and clean the grove out with something like a small flat blade screwdriver.Make sure its open where it bolts on.It gets its oil through the bolt holes.If you have a way to blow the dirt out it helps.You can try running the saw without the bar on to see if its putting out any oil.If not you will have to get to the oil pump to see if its not bad.
First off, take off the bar and chain, clean up the grooves and the small oiling holes in the bar. Then without the bar on, start the saw, see if oil comes out of the oiling hole, if not, dump the oil out of the saw, put some gas in, rinse out well, spray brake cleaner works well, too. Refill with oil and see if its oiling yet, make sure to check if it has an adjustable oiler, open it up a bit if need be. Use only bar and chain oil, not car oil!
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
