Use the first part of the model number to fid who the manufacture of the saw/ motor is. Example: 110.123456- 110 is Whilpool. Then cal the manufacture direct. Also sometimes Grainger has direct replacements.
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some mo
The
motor has a manual reset thermal overload protector switch. If the
motor overheats for any reason, the overload protector will shut off the
motor. The motor must be allowed to cool down before resetting the
overload switch and restarting. It is located on the motor
housing on the side opposite where the pump and hose connections are.
The reason this switch shuts off is because of low voltage problems
caused by either a too low amp rating on the circuit it's
plugged into or by using an extension cord. It is always safer and
better for the motor to run longer air hoses than to use extension
cords.
I had the same problem and the solution was to manually press the thermal overload button. The button is located under the tool box next the motor head. I do not believe I tripped the thermal overload during use, but I suppose anything is possible.I’ve been using the compressor in sub 40 deg F. temperatures.I found the following in the Owner’s Manual, but had to look at the part manual to locate the switch. MOTOR THERMAL OVERLOAD PROTECTOR: The electric motor has a manual thermal overload protector. If the motor overheats for any reason, the thermal overload protector will shut off the motor. Turn pressure switch to the “off” position and wait for unit to cool before pushing the reset button and restarting the compressor. Good Luck!
It is not the thermostat clicking but the compressor thermal protector. Unplug this unit before the compressor is damaged! You need to replace the compressor starting relay. You can buy a new relay at your local appliance parts outlet. Replacement is very simple.
Overload thermal protector is tripping out. When a mechanical refrigerator is unplugged it should remain unplugged for 5-10 minutes to allow the refrigerant pressure to equalize. If you unplug it and then plug it right back in the overload will open on and off until the pressure in the system balance to the point where the compressor will start.
This protector is a two way protector. It opens on Over current and or over temperature. If a condenser is plugged with dust , hair or what ever the fan which circulates the air for cooling the system will not move enough air to keep the compressor with-in operating temperature range. The thermal protector will open.
