F2
Oven
too hot
Check
oven
temperature sensor
The problem is either with the sensor or the wire between the sensor and the control panel.
The sensor is the metal rod that is inside your oven, it comes in on the back wall and is a little smaller than a pencil
Hello there"
The F 2 error that you are getting is telling you that the temperature sensor is going bad and needs to be replaced the temperature sensor is what senses the ovens temperature say you have it set for 350 when it is at 350 the sensor tells the oven to stop heating up and when it gets to a certain temp below that value it will make the oven heat up again
it looks like this
