I bought a 32'' about a year ago. we installed it flat against the wall in our bedroom. I have moved and now want to put it on the top of a chest and use the stand that came with it originally. I have the stand and the other attachment piece BUT NO SCREWS. Where can I find the screws and how do I put it together?
SOURCE: Removing bottom stand Flat Panel LCD Magnavox 32MF605W 32
There are 4 shiny screws at the back of TV just above the stand neck. Unscrew those 4 scrws and then lift the TV up, stand will come out.
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
SOURCE: Base removal of mounted plasma
Pls do not take any other screws, other than silver screws.if you take the 6 pcs of silver screws and pull the stand it will come out easily.
SOURCE: Lost Screws for stand for Insignia IS-LCDTV32 32
they are couse scews your best bet is go to lowes or home depot and get a few of each 1/4 inch screws to see which one fits they only cost about .03 each
please rate my answer it is much apreceated
SOURCE: Insignia TV stand screws
Had same problem with Insignia TV...#12 - 24 x 1/2" machine screws...found at Home Depot in bagged items (can't use longer because some of the holes don't go all the way thru)
