There was already one E74 error report with halo reach beta, I just got the E74 with one light today around 3pm after playing the last game of halo reach beta. Did any one else get the E74 error with the halo reach beta?
As you have mentioned that you got a E74 error problem which you got fixed up, E74 problem is a hardware related issue so the problem you are now facing is linked to a messed up dvd rom firmware issue.
It is very much possible that post you have fixed E74 problem your dvd-rom firmware could have gone corrupt and now is not recognizing the game discs and only playing dvd's
It would be advisable to send your unit to MS support if in case it is under warranty
IF THIS TRUELY ACURES EVERYTIME YOU TRY HALO 3 AND NOT ANY OTHER GAME, YOU HAVE ONE OF THE RARE BAD DISC'S. SEND IT TO MICRO SOFT AND THEY HAVE A PROGRAM CALL DISC EXCHANGE, FOLLOW THE INSTRUCTIONS IN YOU XBOX.COM SERVICE SECTION ON THE WEB. YOU'LL BE PLAYING HALO 3 FINDING YOUR SKULLS IN NO TIME. THE ERROR MESSAGES COME FROM TWO PLACES. EITHER YOUR DISC WITCH IT WILL STATE DISC ERROR, OR CONSOLE ERROR, WITCH USALLY GOES AWAY. CHECK ALL CONECTIONS BEFORE SENDING THE CONSOLE IN FOR REPAIRS. REPAIRS COULD TAKE TWO TO THREE WEEKS. HAPPY GAMING AND HOPE TO SEE YOU IN GEARS OF WAR 2.
you are seeing one red light on the powerbutton and E74 on the screen?
E74 can only be caused by either the HDD or the console itself,so you might wanna try using a different HDD with your console, if the issue still persists, then most probably, the console is having a hardware failure,there is a possibility that the HDD PORT is not properly woking w/c is causing the e74 error.
if thats the case, try calling xbox support hotline(1-800-4-MYXBOX) to process a repair for the console,it will be free,because Microsoft is extending the warranty of the consoles for 3yrs from the date of purchase for e74 and 3red light issues.
or you can also process a repair online,that is available at service.xbox.com,just click on "repair my console"
the odds are very good... The error is caused when there's a problem with video, either because
the A/V cable used is broken, or what's even worse, when Ana, the Xbox
360 hardware scaler chip is damaged.
Also try this take the AV cable, plug it out and plug it in, if it still
doesn't work unplug it, wipe the metal part with a soft cloth then
plug it in. That might help.But i bet you will end up sending it off again.
Heres the problem Section 4 is flashing red - Hardware Failure
Specifically E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
If changing the cable doesnt work then you will need to get it fixed by Microsoft
Check the documentation that came with your Xbox 360 for contact information.
In the US Customer Support can be reached at 1-800-4-MY-XBOX (1-800-469-9269)
Hi this sounds like what happened to mine and also started with Halo 3 now it happens with all my games. Eventually you will get a red light flashing its the E74 error and will have to be sent to microsoft. The E74 error is a problem with either the AV port the Graphics chip or the AV cable itself
this sounds like the e74 error ,these dots will make the screen fuzzy like cod 4 and 5 its the video chip thats near the av cable slot need service and can result to one ring of death aka e74 error.
