Question about Crown CE1000 2-Channel Amplifier
CE1000 2-Channel Amplifier: when i plug my input from my digital baord the amp...
When i plug my input from my digital baord the amplifier begins to fault. We took the amplifier out and cleaned the dust out however the same issue persists
6ya staff
SOURCE:
petraman7
Scott Frye
  • 1175 Answers
SOURCE: 6000d amplifier cutting off
Hi...
Crown has posted on their website all the tech info you can probably use for your situation.
Cheers!
Posted on Jan 18, 2009
Anonymous
  • 121 Answers
SOURCE: blinking red fault warning
timy check the speaker conections before condeming the amp
Posted on May 01, 2009
ABRsvcs
  • 4234 Answers
SOURCE: i need the schematic for the crown amplifier
These are available for purchase from Crown. Generally they are not available on the web. Is there a specific problem that you are having?
Dan
Posted on Jun 29, 2009
Anonymous
  • 10 Answers
SOURCE: i have my amplifier connected to my dj system only
The XTI 2k has lots of DSP options built into the front panel. If it's your intent to run the amp in bridge mono for subs be sure than you have all settings set correct for the DSP, it's very possible that channel 2 will render in-active.
This also applies in the case if you wanted to run your subs in stereo and the internal settings are set for bridged mono.
Another possibility would be if the DSP was set with a crossover. If you put a cross-over point (Low Pass Filter) on the high side of the sub, if becomes the High Pass Filter of Channel 2. Audio would pass if there was no other filter sets, but would not if you were using a crossover and then hitting the subs.
Posted on Sep 24, 2009
Grubhead
Grubhead
  • 5699 Answers
SOURCE: XTi 2000 2-Channel Amplifier: when power is switch on amp don't play i have to t...
A loose wire or bad solder connection.
Posted on May 16, 2010
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
I have vestax 05pro2. Left channel works but out of one speaker. The turntable input is good. Im thinking Its either the channel fader, or the rca inputs for that side. Has anyone had this problem?
Here's a solution to see if you have a problem with either your receiver or turntable.
The turntable has 2 RCA's one red for right channel, and one white or black for left channel, which plug into the back of the amplifier.
  • Unplug both RCA from rear of amplifier.
  • Plug in a cd or dvd player into those inputs on the amplifier, the sound will be lower but it will give you an indication if the amplifier is ok or not.
  • If you have sound on both channels left and right then the amplifier is good
  • If you still only have sound on left channel, then there is a problem with the right channel input on the amp.
  • If your amp, is good, unplug the cd /dvd player.
  • Put a record on and start playing the record
  • Plug the white or black RCA from the turntable into the rear of the amplifier marked left, you should have sound.
  • now unplug it from the left and plug in into the right red RCA socket, if you have sound the amplifier is working fine.
  • if there is no sound there may be a problem with the stylus cartridge on the turntable
  • now lets reverse the test
  • unplug both RCA from amp.
  • Plug the red RCA into the left socket on amplifier, if there is sound, turntable is working fine, if no sound there is a problem with either the stylus cartridge or that red RCA cable.
  • now unplug the red RCA from the left side and plug it into the right side socket
  • if there is no sound there may be a problem with the stylus cartridge or RCA cable.
I hope this helps
MobileJB
Jul 15, 2011 | Audio Players & Recorders
Sonance ASAP1 2 channel amp/switcher keeps blowing fuses. I'm using the 1A-250V slow burn fuses like it states on the rear panel. I plug it in and it instantly blows the fuse.
If fuzes burn out at connection to computer , that necessary to check:
1 Presence of the earth between body PC and amplifier.
2 Levels of the signal at the input amplifier must be minimum.
Jan 03, 2011 | Sonance ASAP1 2-Channel Amplifier
Can this present amp use microphone? because i need the one with mic input for my project
No, you have to use a mixer or a microphone pre-amplifier.
The inputlevel of those amps are to low for a microphone.
regards,
Gerard
May 07, 2010 | Yamaha P4500 Power Amplifier 2-Channel
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
McIntosh MA6100 integrated Amp Phoho input crackiling
These units are capacitor coupled between stages. It sound to me like one or more of those caps are defective. There is an extra stage of amplification for the Phono inputs. Check the phono pre-amp section for defective caps. Dan
Jun 08, 2009 | Mcintosh MC602 2-Channel Amplifier
Peavey 1500 PA amplifier, no output from channel A
is amp configured correct
use same input and same speaker on both sides
check output fuse on A
if fuse ok then problem is inside unit
get tech to open and check all input and output wiring
Jan 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Only the right channel working on the amplifier
first check on all your cabling, speakers and input sources for loose/defective cables. can you tell me what brand is your amp and model? does it employs digital source switch or mecahnical switches only.
Aug 12, 2008 | Audio Players & Recorders
Crown CE1000 2-Channel Amplifier Logo
83 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
