Nikon Coolpix 5700 Digital Camera Logo
Posted on Apr 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor How does one alter the monitor settings lighterr/darker
Anonymous
Level 3:
Master:
  • Master 619 Answers
  • Posted on May 23, 2008
Anonymous
Master
Level 3:
Master:
Answers
619
Questions
0
Helped
350782
Points
1019
Hi , press menu you can find adjustment in monitor lighter and darker.
Why my monitor screens is color green
Your RGB settings has most likely been altered, resulting in some problems. Check your settings menu on the monitor itself and reset the settings to default. If that is not the problem, it's probably the computer's settings that has caused this change. You will need to go to the computers monitor settings and reset that to default to get back to normal colours.
2helpful
My lcd monitor have red lines
Try altering your display resolution in all its variables.
If the monitor has a menu, try altering RGB settings, contrast and appearance settings. If this does not work, most likely a hardware screen failure.
1helpful
My photos print out way darker than the monitor shows this happens with two different printers...I need tips on how to adjust it. NOT a computer person ;)
Hi this could be your printer aswell, your printer could be printing the colours in darker then it should, or if it is this Screen , then your screen is probably set too bright then it should making everything lighter and brighter
Thanks
Monitor Colors Black is now RED
Right click blank screen and selsct properties the the settings are there just alter what you want. I think its the back round colour that needs altering...
Acer AL1916 LCD monitor is getting darker!!
sounds like backlight is failing,contact acer and see if its under warranty.
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Streaks make letters fatter every 2 inches apart across screen
this is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
3answers
How do i reset my monitor back to its factory settings?
Setting via the control panel front bottom of the monitor.
Severe gradient issues / problems with darker grays
So your sure when you go into the monitor settings, and color, it is set to like 9300k or something? It probably isn't the monitor, because the video games you said display just fine.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
