Cell Phones Logo
A
Anonymous Posted on May 14, 2010
Want to know if i can pair my hfblu-lt100 bluetoo...
Want to know if i can pair my hfblu-lt100 bluetooth to my computer
ace freely
Level 1:
Sniper:
  • Contributor 67 Answers
  • Posted on Jun 13, 2010
ace freely
Contributor
Level 1:
Sniper:
Answers
67
Questions
0
Helped
17623
Points
I have a blu too model hfblu-lt100 i need the password to put in my cell phone
the primary pass word for this product is zero-zero-zero-zero. good luck!!!!
1helpful
I put my HFBLU-LT200 bluetooth headset on charger and both blue and red light have turned on permanently. Bluetooth has stopped working
That usually means it isin pairing mode. Charging some headsets from extended periods can sometimes reset the device requiring you to pair the device again.
8helpful
How do i connect my hfblu-lt100 to my phone?
hold down the multi-function (power) button until you see a red/blue lights flashing on the piece at the same time. once you see this the unit is in pairing mode and you just have to have your phone search for a new device or add a new device..once it finds it just follow the prompts on your phone. passkey is "0000"
2helpful
Can not find Blutooth Headset, Model: HFBLU-LT100 , on my Blackberry Pearl Cell phone.
Please make sure the bluetooth is in pairing mode, you know this when the unit is flashing red/blue at the same time. you can achieve this by first turning the unit completely off. once the unit is off then hold down the power button until you see the re/blue flashing light. then have your phone search for a new device again. if this does not work you can always take the battery out of your phone while it is still on (for about 5-10 seconds) so that it can reset. then try the process again.
Passkey not working to pair headset to phone
with your phone STILL ON remove the battery, wait 5-10 seconds replace battery..power up phone and try to pair. should work after phone resets itself.
HFBLU-LT100BK Bluetooth keeps "pairing failed"
headset won't pair with me phone and i have tried 0000 and 1234 and 12345
2helpful
HFBLU-LT100 pairing a second phone
Canadian Tire's HFBLU-LT100 (BK-600) won't connect to my SPH-m300 Samsung phone but I entry of the passcode (0000) about 20 times before it connect successfully.
25helpful
3answers
Need a users guide (instructions)
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
22helpful
4answers
BT pairing code
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
