I went into the menu and changed the setting to turn on the progressive scan mode ,, and lost picture,,now i cant see the menu to try to turn it back on,,any help will be great,,it asked if my tv supported progressive scan before i changed it and i did it anyways thinking it did,,eveidently it does not,,, need help asap,,
After unsuccessfully trying to naviagate the menu , i unplugged the dvd player for 10 or 15 min. then plugged it in again and changed the output i had it plugged into,,from video 1 to video 2 and i got my picture back it seems fine now
Try these methods for resetting the scan on your dvd."To reset the VIDEO OUTPUT, turn Off the player, turn back On, open
the disc tray and press and hold the Stop button on the player for 10 seconds to
reset the scan mode." The Reset procedure
doesn't seem to work on all versions but you
can sometimes get a usable B&W picture allowing you to get to the menu and
change the settings by connecting the composite video input of
your display to the Red Pr/Cr or Green Y component output jacks on the rear of
the cabinet. You
can also go into the Menu and set it blind with the following key presses
on the Remote: 1.
With the unit Stopped, press Setup. 2.
Press Enter. 3.
Press the Down Arrow 3 times. 4.
Press the Right Arrow Once. 5.
Press Enter. Hope this helps you with your problem
You have to blindly instruct the NTSC/PAL menu item, which toggles between NTSC and PAL;
This is how it is done:
1) turn your dvd player off.
2) Turn it back on and make sure there is no DVD in the player tray.
This will ensure the menus are active
3) Using the remote, press the dowm menu selector key exactly three times
4) press the center menu select key once.
This will activate the display adjustement menu
5) press the down menu key exactly once.
This will activate the NTSC/PAL menu
6) press the center menu key
DONE.
The player should now have switched back to NTCS if it was in PAL.
IF it was in NTSC it should have switched back to PAL.
Note: If you still have the manual you can follow the menu tree blindly using the instructions in the manual. The above sequence is for activating the NTSC/PAL menu.
This player can also switch to progressive scan, which creates a similar problem. At least the progressive scan menu has enough warnings before it will actvate.
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
follow the steps it may help !!
Press STOP button.
? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display.
Press and hold P.SCAN button on the remote control for over 5 seconds.
? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan"
alternately.
? When you select P.SCAN, "P.SCAN" will appear on the display.
? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play.
regards
sreejith
To change from p-scan back to i-scan with no video picture, mu1 model:
1.turn dvd on with no disc, wait 10 sec.
2.press "setup"
3.press "down arrow"(selects audio/video)
4.press "enter" (selects audio/video menu)
5.press "down arrow" 4 times (selects scan mode)
6.press "right arrow" (selects scan menu)
7.press "up arrow" (selects interlace mode)
8.press "enter" (should see picture)
Or find a tv with p-scan capability
If you set progressive scant On by accident,you must reset the unit.
Remove any disc from the unit and close the disc tray. See that "disc" is displayed on the display window. Now press STOP and hold it for more than 5 seconds before releasing it. The video output will be restored to the standard setting and picture will once again be visible on a conventional analog TV or monitor.
