Press and hold the "Menu" button and the "Play/Pause" button together if using an iPod Touch. Press and hold the "Menu" button and the "OK" button together if using an older iPod. Continue holding the buttons together until the screen flashes and then displays the iPod name and the Apple logo. Release the buttons. Wait as the iPod resets itself and turns itself back on. Leave the iPod connected to the USB connector so that it can fully charge the battery. Remove the iPod from the USB connector. Navigate to a song using the menu selection and play some music
Go on to itunes and plug your mp3 in to your computer and download it and salect which tunes you want. If it dose not work
there is somethind wrong whith your mp3
If you repeatedly enter the wrong passcode, iPhone or iPod touch
will be disabled for longer intervals, before you can try again. After
too many unsuccessful attempts, you won't be able to try again until
you connect to the computer you normally sync with. Note that starting
with iPhone 2.1 software, there is a setting to cause the device to
erase itself after 10 consecutive incorrect password attempts. This
setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode.
If you cannot remember the passcode, you will need to restore your
device on the computer that was used to originally sync the iPhone or
iPod touch so that you can reset your passcode and resync the data from
the device (or restore from a backup). If you restore on a different
computer that was never synced to the iPhone or iPod touch, you will be
able to unlock the device for use and remove the passcode but your data
will not be present.
press and hold the home and power buttons, when it turns off DO NOT let go of the home button continue holding until it restores itself then connect it to your computer and restore it. unfortunately it will erase everything.
