What problem are you having, the problems i have seen with kenmore elites are below.
1. when you press start and release dryer shuts off
for this problem, change the board in the console
2. not producing heat
for this problem, check to see if 220 is getting to element, check to see if you are getting 220 from outlet, check your thermal cutoff on heating housing, check your heater relay which is located in top console.
I need an owners manual for Kenmore gas dryer model number 97511100 Thank you
I found Owners manual/guide by going to www.managemyhome.com. There were many Kenmore gides. I think you have to use "elite" in title, and getting model number is tricky. My model number on machine said "42926', but the whole number is 110.42926200. IF your on another forum, let people know, apparently there are a lot of people searching for this brands owners guide. good luck.
Need an owners manual for kenmore dryer model 110
Although this is for a whirlpool( your machine is made by whirlpool) this should be what your lookin for, anly kenmoore guides i found sears wanted to charge for
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
SOURCE: just inherited a kenmore elite oasis dryer model 110 77092600
Go to Sears and buy it! You cheap B.
SOURCE: Kenmore Elite dryer won't heat
if no heat at all unplug the dryer take off the vent take out the screws holding the back on there is a long oval shaped tube with two wires going into it there is a holding bracket holding it in place take out the screw unhook the wires take out a screw holds the heating coil in take out that screw inspect the heating coil for breaks it sounds like it is burned out if so replace if not it is probably the oval shaped thermostat on the tube i do hope that this was helpful then reverse the procedure, thank you.
The AF error code for Kenmore Elite Oasis dryers with model numbers 11067032601, 11067042601, W10035200, 11067032600, and 11067042600 indicates that the dryer is experiencing an airflow problem. The Kenmore Elite Oasis owner's manual recommends four troubleshooting solutions to an airflow problem: clean the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Read more: Error Codes on Kenmore Dryers ' eHow.com http://www.ehow.com/list_7192588_error-codes-kenmore-dryers.html#ixzz1MuOgWsZC
it is found also on this link above by clicking the link if you have any further questions please message me back and your dryer should be dlinted at least once per year to avoid dryer breakdown you can also see how to dlint your dryer by clicking this tip that I wrote http://www.fixya.com/support/r8732702-prolong_life_dryer
I await your reply if you have any further questions Thanks Rick
I have an older model gas dryer it is a Kenmore Heavy Duty Model 110-87340100 serial#m30310502 I need scamatics or owners manual to replace belt allready have the part
model 110.86984110
