Question about Peugeot 307BR Wrist Watch
Condinsation in front light of peugeot 307 sw
    New Friend:
Porchase a pack of small condensation collection bags [about
Posted on Sep 08, 2010
    New Friend:
Remove light cover insert vacume cleaner while sucking use hait dryer on outside untill clear
Posted on Sep 06, 2010
Anonymous
SOURCE:
What is valve clerance and procedure for setting valves on a peugeot 307 petre 1.4cc
Works on the rule of 9 eg. If the first valve is down u adjust number 8 if number 4 is down u adjust number 5 etc number 1 is cambelt side and rotate engine clock wise hope this helps
Nov 19, 2014 | Peugeot Watches
I want to size my wife's Peugeot ceramic watch band to fit her small wrist. Any suggestions? Thanks.
I just got finish resizing the White Ceramic Peugeot watch I bought my wife. It's very simple to do
Feb 12, 2011 | Peugeot Watches
Got a high bite point does my clutch need replacing on my peogeut 307 02 plate
If you have to lift your foot off the floor to let the clutch in, then the plates are worn out and may soon stop driving.
Replace them soon!
Aug 04, 2010 | Peugeot 307BR Wrist Watch
307 2006,floorwell is wet in passenger side and has a nasty smell ,i think its antifreeze,i recently had a new timing belt ,the old one snapped and did a lot of damage,it has only started since then,could...
it is possably your heater matrix which is located under the n/s of the dashboard.
you could try using a product called k-seal which you put into the coolant bottle when the engine is hot.
what this product does is perminently seal leaks in the cooling system.
Dec 07, 2009 | Peugeot 307BR Wrist Watch
Swiss army stopped, im stressing..
If it's a quartz (battery powered) watch test the voltage of the battery. If below 1.5v then replace with new. Ensure battery contacts make good contact with the battery and are free of corrosion/rust/contamination of any sort. Check operating manual for any specifics regarding battery replacement proceedure.
Jul 26, 2009 | Watches
Swiss army stopped
If qz. see previous answer. If it's mechanical and absolutely all the moisture is not eradicated then rust may begin to form and will over time cause damage. So if it's mechanical take it to a watchmaker for servicing asap.
Please rate my solutions.
Jul 26, 2009 | Relic 0504648FA
How do you remove the fuel filter on a peugeot 307 hdi?
open the bonnet. Look where the Clutch & Brake Oil Pan is. Right under this on Engine there is a black plastic round shaped with fuel pipes for inlet and outlet. Remove the car battery from tray (you need rachet with long beck to open bolt). From this side have a look and you'll find a bolt (need star key screw driver) open this bolt remove inlet and outlet pipes by pressing the button like lockheads on these pipe ends and pulling outside and the power adapter plug below the filter.Pull the filter ( you might be needed to remove turbo air filter case and pipes in case if the filter is stucked with a leg in the engine bracket). Here is your Diesel Filter in your hands. Took me about two hours for replacing the filter.
Jul 20, 2009 | Peugeot Square Case with Crystal Bezel...
Indicator arm faulty
In modern cars internal parts of an indicator stalks are mostly plastic so forget about repairs. New indicator stalk costs you a fortune. go to ebay and buy a second hand. be very careful if its a DIY job. remove the battery clips to avoid air bag explosion. carefully remove the cover including air bag from the steering. spin the steering to bring it in middle along with your tyres in a straight line. loosen the steering nut and remove airbag wiring plug. unscrew the plastic cover around the stalker. now you'll see stalker with mainly three wiring plugs (it was in my case). unplug it and don't mix it up if possible number it with permanent marker. lose any screw or bolt holding the stalker on its place. remove the old stalker and place the new one. just tight one or two screws and put the steeing on rod and test it by moving the steering left and right side to check the indicator stalks operation (don't connect the battery clips just do it as a cold test because sometimes you'll hear a big clunk noise if stalker tooth is not adjusted in neutral position. take a long beeck type screw driver and push this tooth slightly either up or down (left or right). don't apply too much force as it then don't stays in middle and will go automatically in opposite direction and you have to move it back to get in the middle. If fitted correctly you'll not hear any noise. just test it for left and right indicator. Now the assemble the whole work in reverse order and don't forget to connect your airbag in the last stage. Hope it'll help you in anyway. If you're not willing to do it let it done by a garage. costs you around 60 pounds.
May 07, 2009 | Peugeot 307BR Wrist Watch
Peugeot 307 speaker changing
There is no way around with out removinf the panel, u ll have to remove then only u can gain access to the fixing screws to replace the speaker.
For your Sunvaley...
You have to remove all the below listed to remove the door pad
  • The switch block bolt
  • The switch block
  • The exterior mirror fasteners interior cover
  • The interior opening control trim
  • The 3 fasteners (screws) 3 on the trim
  • Slowly pull out the trim without excessive force, to avoid brekage of the clips inside
Apr 25, 2009 | Peugeot 307BR Wrist Watch
Peugeot 307BR Wrist Watch Logo
165 people viewed this question
Top Peugeot Watches Experts
Janelle Schoonover
Janelle Schoonover
Vernon Taylor
Tom Chichester
Are you a Peugeot Watch Expert? Answer questions, earn points and help others
