Washing Machines Logo
Anonymous Posted on May 19, 2010
I took something out of the washer i should not
I took something out of the duet washer i should not have and need help explaining how to get it back init is not my washer and i recently moved into this place and I do not want tell my landlord i broke his washer because i feel bad please get back to me soon
  • Anonymous May 20, 2010
    i took the part out of the top where the fabric softener and the bleach goes in. That long piece That is vertical to the right of the other ones where you put your detergent. now it wont go back in at all no matter what i try it gets caught and wont go back further and the pieces that are suppose to go down in there spots wont go down...
Anonymous
Level 2:
  • Expert 254 Answers
  • Posted on May 20, 2010
Anonymous
Expert
Level 2:
Answers
254
Questions
0
Helped
90834
Points
735
  • Anonymous May 21, 2010
    i m tryin to think of the part it seems like a divider of some such.... go to searspartsdirect.com and enter the model number of the machine on inside on sticker, it will give u a parts breakdown and tell me the name of the part u are haveing trouble with..... so i can understand beetter, but right now it seems that nothing is broken its just a matter of u installin it correctly, well the whole dispenser bucket can be pulled out to reinstall make sure the metal bar on very back top goes in under top and it is lined up straight and should push straight back, also those divders neeed to fit into the grooves on the assembly it might just be a matter of trying and retrying until u get it , get bak to me if u want i will try to help soory
Installing a bellows gasket onto duet sport whirlpool washer
The following link explains step-by-step how to replace the door bellow on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you haven't purchased a replacement yet, you can find one at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope you find this information helpful.
1helpful
Washer wont spin ...motor runs but drum doesnt
If this is a Duet front loader, you need to check to see if the drive belt may have broken, or slipped off the drive pulley behind the wash tub.
To access and replace/reinstall the belt, the following link explains:
http://www.fixya.com/support/r3609900-drive_belt_installation_whirlpool_front
If you have any questions, or if the model washer you have is different, please post back and let me know. I hope this helps you.
1helpful
How do I change the door gasket on a Whirlpool Duet washing machine model WFW8300SW03 I have the new part
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: You can view helpful exploded view diagrams of your washer at searspartsdirect.com for assistance as well.
1helpful
Water seeps into Whirpool Duet washer
If your washer is leaking water when it is not in use, the following link explains how to troubleshoot to isolate the cause:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
The problem is either attributed to a defective pressure switch or a water inlet valve that is leaking by. The link I provided will explain how to determine which one.
If you still require assistance, please let me know.
My whirlpool duet washer leaks. It is not the
The following link explains how to determine where a leak may be coming from in a Whirlpool Duet:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In many cases, the rubber bellow (door seal) is the source of the leak and will need to be replaced. If the bellow is ripped or torn the following link explains step-by-step how to replace one:
NOTE: THe bellow does wear out from time to time and will need to be replaced. However, using too much detergent, the wrong type of detergent, or loading the washer excessively can contribute to premature wear and tear and deterioration.
If you have any questions, or are having problems determining where the source of where your leak may be coming from , please post back and let me know. I hope this helps you.
1helpful
How do i install a new pump for my Duet washer
The following link explains step-by-step how to replace the drain pump on a Whirlpool Duet:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
2helpful
Controls locked
The following link explains how to correct a control lock problem on a Whirpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If these instructions do not correct the problem for you, please post back and let me know. Your problem may be something more than just a simple operator control issue. If you have any questions, please let me know. I hope this helps you.
Error 2 F
The "F2" error is called a Long Drain error. It is usually attributed to something clogging the drain pump and/or drain lines. The following link explains how to check:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If something has damaged the pump impeller, you may have to replace the drain pump. If you have any questions or require additional assistance, please let me know. I hope this helps you.
Duet f h code
The following link explains the "FH" error and how to diagnose it. Let me know if you have further questions.
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
