Posted on May 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not able to locate B2510 and D1510 - Sherwood A-965 Amplifier
Steve Allison
Level 3:
  • Master 5,569 Answers
  • Posted on May 19, 2010
Steve Allison
Master
Level 3:
Answers
5569
Questions
Helped
2002200
Points
16452
It would have been helpful to know on which kind of component you found these numbers but since you didn't, I'll just guess:
Power transistors? (You could at least mention how many leads next time.)
If so, add the characters '2S' in front of each (such as: 2SB2510) and you might have better luck.
2answers
How do I Change preferences for my Home location when it is wrong on my tablet?
  1. Go to the settings app: On most tablets, the settings app can be found in the app drawer or on the home screen.
  2. Locate the location settings: Look for a section labeled "Location" or "Location & Security". The location settings may be located under the "Device" or "System" section.
  3. Turn on location services: Make sure that the location services toggle switch is turned on.
  4. Change the home location: Look for a setting labeled "Home" or "Home Address". Tap on this option to open a map view. Use your finger to move the pin to the correct location.
  5. Save the changes: Once you have the correct location set, tap on "Save" or "Set as Home".
Note: The steps may vary slightly depending on the specific model and operating system of your tablet. If you are unable to find the location settings, try searching for "location settings" in the device's search bar or help center.
Delete a shared location through text messages on iPhone 6
Here's how to disable Location Services after you use the Share My Location feature:
1. Open your Settings app
2. Tap Privacy
3. Tap the Location Services panel
4. Tap the Location Services slider so it is White / OFF
You can stop sharing your location in iMessage as Daniel said.
2answers
My car smoke while the engine is on
Turn it off. Dont lift the bonnet until its cooled down.
have patience and then pull up the bonnet to see where the problem is.
3answers
Squealing noise in park
If youre just idiling, then it may just be the serpentine belt that needs to be replaced.
2answers
When driving sounds like an electric motor is running
Check power steering fluid and or tranny fluid.if low check for leaks.,., fix or repair.,., or just fill see if it stops. Do not over fill .,.? , get back to me
2helpful
Where is the oil presure sending unit in an 1996 pontiac grand am manual 2.4 liters 4 cylynders.
Here's a copy of component locations for various engine sizes for the 1996 Pontiac Grand Am that I had on my online resource.prev.gif next.gif COMPONENT LOCATIONS The component locations shown are typical, and may vary slightly from one model year to another, because of variances in manufacturing and assembly. Fig. 2: 2.0L Engine Component Locations 91064gtt.gif
Fig. 3: 2.3L Engine Component Locations — 1988–90 91064gtu.gif
Fig. 4: 2.3L Engine Component Locations — 1991–93 91064gqa.gif
Fig. 5: 2.3L Engine Component Locations — 1994–95 91064gqb.gif
Fig. 6: 2.5L Engine Component Locations 91064gtw.gif
Fig. 7: 3.1L Engine Component Locations 91064gty.gif
Fig. 8: 3.3L Engine Component Locations 91064gtz.gif
1helpful
How many oxygen sensors are in my 95 oldsmobile aurora? and where are they located?
LOCATIONS There are different locations in the exhaust system where O2S sensors are positioned. The locations have been given numbers and will be used in the accompanying charts to identify the positions of O2S sensors in most vehicles. Due to mid-year production changes or factory inconsistencies, all models may not be covered. If a vehicle being serviced is not covered in the charts, inspect the exhaust system (while cold!) in the general locations to find the applicable O2S sensors. NOTE: If equipped with dual exhaust systems, there may be up to 4 or 5 O2S sensors in the exhaust system. Be sure to locate all of them before commencing with any testing or service. Fig. 1: Location No. 1 — down pipe or exhaust manifold 79248g01.gif
Fig. 2: Location No. 1 — typical O2S sensor located in the exhaust manifold 79248g04.gif
Fig. 3: Location No. 2 — left and right banks of a V-type engine 79248g02.gif
Fig. 4: Location No. 3 — exhaust collector (where more than one pipe joins together) 79248g05.gif
Fig. 5: Location No. 4 — outlet of the catalytic converter 79248g06.gif
Fig. 6: Location No. 5 — inlet and outlet of the catalytic converter 79248g03.gif
4helpful
2answers
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
6helpful
3answers
Sherwood rx-4105 output transistors
You can also use 2SD2560 and 2SB1647 130watt 150volt 15amp transistor, but it may require some rebiasing the on output transistors. Sherwood have used these transistors in their older model receivers. I just replaced those transistors in my Sherwood RX-4105 Receiver, and they work good as well.
Before I install those transistor. I did a out of circuit 20volt 4amp DC current test to a 4ohm resistor @ 200watt load to compare 2SD2560 / 2SB1647 to the B2510/B1510 mounting them on 5 square inch, 1/8" thick piece of Aluminum, and the results of the test, the 2SD2560 / 2SB1647 heats up in 60 seconds to around 120 degrees F, and the B2510 and D1510 heats up in 30 seconds to around 120 degrees F.
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Ngoro
Arnie Burke
Arnie Burke
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
